Unexpected output on Split Out node when using dot notation
I’ve just used the Splitout node and wanted to keep a value “person.label” and used the dot notation option to enable that field from carring over.
Here is my simplified workflow:
input json:
    "persons": [
            "first_name": "Max",
            "last_name": "Mustermann",
            "phone": "004404404444"
            "name": "Maria",
    "person": {
        "label": "Grün"
Expected output:
        "person": {
            "phone": "004404404444",
            "label": "Grün"
        "person": {
            "name": "Maria",
            "label": "Grün"
actual output:
        "person": {
        "person.label": "Grün"
        "person": {
            "name": "Maria",
If I understand that correctly, the dot notation gets used on the input side of the node ,but not on the output.
Is that expected?
A solution without a breaking change would be to add a option to the splitout node which enables dot notation for the output seperatelly to the input.
Also found another post without an answer about this “issue”:
  • n8n version: 1.65.2
  • Running n8n via (Docker, npm, n8n cloud, desktop app): Docker, queue
  • Operating system: Server: ubuntu 22.04, Client: Win11 Firefox
Hey @FelixL , it works as expected.
To achieve what you want, add Set node as below.
