Unsupported parameter: 'max_tokens' is not supported with this model. Use 'max_completion_tokens' instead
I am using tools AI agent (with OpenAI o3-mini model) for one of my automations. I get the following error when I assign max tokens.
Unsupported parameter: ‘max_tokens’ is not supported with this model. Use ‘max_completion_tokens’ instead.
While the error is self explanatory. I can’t find the option max_completion_tokens there.
Hi @rahulm,
Tip for sharing your workflow in the forum
Pasting your n8n workflow
<your workflow>
Make sure that you’ve removed any sensitive information from your workflow and include dummy data or pinned data as much as you can!
I couldn’t reproduce your issue, could you tell me which version of n8n you’re using and paste the workflow json of the AI Agent so we can have a look at your setup? (See above on how to paste your workflow here)
Please see the AI agent node I’m using.
n8n Version 1.79.3
@aya Can you please take a look at this when you get a chance? Thanks.
