Hey @t10i,
I will need to double check but I would imagine it is something that will be added as it makes sense to use the token over user credentials.
I have set a reminder on this thread to check in the morning ![]()
Hey @t10i,
Only some Baserow endpoints support token auth - JWT has higher coverage.
https://api.baserow.io/api/redoc/#operation/delete_database_table_row
https://api.baserow.io/api/redoc/#operation/get_database_table
That does seem to be the case. Additionally, JWT tokens only seem to be valid for 60 minutes after creation. So maybe it is best to leave this as credentials since that will always work when using the API.
Maybe that is why it was kept to user and password, It needs them anyway for JWT which looks to be what the node is doing internally. It looks like the Operations for the node can work with Token but the dynamic parts need the JWT side.
Got it, makes sense as to why the credentials are asking for the full credentials and not tokens, thanks!
Hi,
Apologies for reviving an old thread, is this is still the case?
I’m not comfortable having to enter an individual’s credentials.
How should we approach this if the n8n workflow is to be shared?
Thanks.
