Using builtin logging from a Function Node
I’m trying to find the relevant documentation on using builtin logging from a Function Node
I’ve tried the following steps:
  1. Enable support for builtin modules in Function Nodes
    export NODE_FUNCTION_ALLOW_BUILTIN=*
    (as per Configuration | Docs)
  2. Import the Logger
    (as per Logging in n8n | Docs)
import {
	LoggerProxy as Logger
} from 'n8n-workflow';
but hit an error
ERROR: Cannot use import statement outside a module
:1
(function (exports, require, module, __filename, __dirname) { module.exports = async function() {import {LoggerProxy as Logger} from 'n8n-workflow';
I’m running:
n8n ready on 0.0.0.0, port 5678
Version: 0.150.0
I’m guessing this is the issue here:
Also just realised “support for builtin modules in Function Nodes” means Node builtins like fs etc. :man_facepalming:
So would need to enable this configuration instead:
NODE_FUNCTION_ALLOW_EXTERNAL: For external modules sourced from n8n/node_modules directory. External module support is disabled when env variable is not set.
Not the NODE_FUNCTION_ALLOW_BUILTIN
Hey @beaspider
Welcome to our forums!
I believe you have it all sorted out, right?
Thanks for posting the solution as well =)
Thanks @krynble
Yes, I misread the documentation :slight_smile:
I now understand that the Function Node is executing the provided JavaScript using NodeVM and also that the documentation on Logging in n8n | Docs was aimed at Developers of n8n not end users writing Expressions / Function Nodes.
I was trying to use the n8n Logger / LoggerProxy in the Function Node but I guess the cleanest way to do that would mean changing the code in the Function.node.ts
e.g.
    const logger = getLogger();
    LoggerProxy.init(logger);
    // Define the global objects for the custom function
    const sandbox = {
        logger
