I am looking for ideas how to connect an iWatch to N8N, idea is to use a heart rate signal as trigger to send out a message like warning to WhatsApp
- n8n version:
- Database (default: SQLite):
- Operating system:
That is a very interesting use case indeed. Quick search online says apple watch cant post or notify of those type of events but if you find a way to push a notification to and endpoint you could capture it using the webhook trigger in n8n.
Let me know if you find anything, I can see this use case as having some cool uses ![]()
