I have a self-hosted n8n instance running with an Nginx proxy, but when creating the webhook node I am not able to connect it with other nodes.
The webhook URL is ended up with null instead of a path.
Please share your workflow/screenshots/recording
#[details=“instance information”]
Debug info
core
- n8nVersion: 1.107.4
- platform: docker (self-hosted)
- nodeJsVersion: 22.17.0
- database: postgres
- executionMode: regular
- concurrency: -1
- license: enterprise (production)
storage
- success: all
- error: all
- progress: false
- manual: true
- binaryMode: memory
pruning
- enabled: true
- maxAge: 336 hours
- maxCount: 10000 executions
client
- userAgent: mozilla/5.0 (macintosh; intel mac os x 10_15_7) applewebkit/537.36 (khtml, like gecko) chrome/139.0.0.0 safari/537.36
- isTouchDevice: false
Generated at: 2025-09-01T06:49:43.996Z}
[/details]
- n8n version:
- Database (default: SQLite):
- Operating system:
@Roland_Li Hello, have you tried setting the environment variables for both WEBHOOK_URL and N8N_PROXY_HOPS and then restart the n8n instance?
This n8n documentation link might help you Configure webhook URLs with reverse proxy | n8n Docs
@c0d33ngr Thank you for the suggestion! I’ve followed your advice and implemented the recommended configuration, but unfortunately the webhook issue persists. Here’s what I’ve done and the current status:
Configuration Applied:
Environment Variables Set:
Proxy Configuration:
Current Setup:
n8n Version: 1.109.2 (updated from 1.107.4)
Platform: Docker (self-hosted)
Database: PostgreSQL
Proxy: Nginx with SSL/TLS
Domain: https://n8n.mydomain.ai/
Issue Still Persists:
The webhook node still shows null instead of the proper webhook path when creating workflows. The webhook URL is not being properly resolved despite having N8N_WEBHOOK_URL set correctly.
What I’ve Verified:
Environment variables are properly set in the container
n8n instance restarted successfully after configuration changes
Nginx proxy is forwarding headers correctly
SSL certificate is valid and working
n8n is accessible via https://n8n.mydomain.ai/
Debug Information:
shellscript
# Environment variables confirmed in container:
N8N_PROXY_HOPS=1
N8N_WEBHOOK_URL=https://n8n.mydomain.ai/
Next Steps - Need Help With:
How can I debug webhook URL resolution? Are there specific logs I should check?
Should I verify any additional n8n configuration settings?
Are there any known issues with n8n 1.109.2 and webhook URL resolution?
What other troubleshooting steps would you recommend?
I’ve referenced the n8n documentation on webhook URLs with reverse proxy as suggested, but the issue persists. Any additional guidance would be greatly appreciated!
Finally I fixed the issue by:
- Remove the overly strict Content-Security-Policy header from Nginx (it’s blocking eval in the editor and may be causing the null URL)
/etc/nginx/sites-available$ diff n8n n8n.before-csp-change-20250908114344
34a35
add_header Content-Security-Policy "default-src 'self' http: https: data: blob: 'unsafe-inline'" always;
