How can I make a workflow which returns its inputs from the starting webhook, and the output of the respond to webhook node?
I am calling N8N workflows from another page I have using the webhook node and to add the workflow activation, I need the input and output parameters of the workflow itself.
I could go in to every workflow and get the information manually, but is there a better way for it?
Example workflow
"nodes": [
"parameters": {
"path": "7f9be095-02d6-4b03-9a91-cd4e1d1f24f4",
"responseMode": "responseNode",
"options": {}
"type": "n8n-nodes-base.webhook",
"typeVersion": 2,
"position": [
0,
0
"id": "c37e8eb4-2e40-4eae-b3db-c6a7e7c267c2",
"name": "Webhook",
"webhookId": "7f9be095-02d6-4b03-9a91-cd4e1d1f24f4"
"parameters": {},
"type": "n8n-nodes-base.noOp",
"typeVersion": 1,
"position": [
220,
0
"id": "d4661ccf-eefe-48be-bed5-02d5798ad85a",
"name": "Run the workflow"
"parameters": {
"respondWith": "json",
"responseBody": "{\n \"myoutput1\": \"outputExample\",\n \"myoutput2\": \"outputExample2\"\n}",
"options": {}
"type": "n8n-nodes-base.respondToWebhook",
"typeVersion": 1.1,
"position": [
440,
0
"id": "49463c3f-9504-49e1-a5ea-ca3f0c2ad514",
"name": "Respond to Webhook"
"connections": {
"Webhook": {
"main": [
"node": "Run the workflow",
"type": "main",
"index": 0
"Run the workflow": {
"main": [
"node": "Respond to Webhook",
"type": "main",
"index": 0
"pinData": {
"Webhook": [
"headers": {
"header1": "example header"
"params": {},
"query": {},
"body": {
"data": {
"input1": "something",
"input2": "something else"
"webhookUrl": "http://localhost:5678/webhook-test/7f9be095-02d6-4b03-9a91-cd4e1d1f24f4",
"executionMode": "test"
"meta": {
"instanceId": "eaabda8ba70da396a89aa4eab024c418f9af48f01fb72bf1441102e99715b021"
In this case I would like to get the body element of the webhook input and the output elements so something like this:
"input":{
"data": {
"input1": string,
"input2": int
"output":{
"myoutput1": string,
"myoutput2": boolean
It doesn’t really matter what format it has, I just need the input and output variables collected in one place.
Is there a way to make this automatic for all workflows?
Thanks in advance.
Information on my n8n setup
- n8n version: 1.88.0
- Running n8n via: Docker
- Operating system: Windows 11
