Webhook Trigger with an Expression setting the path will not Trigger
Trying to send a post request to a webhook trigger without success, the workflow fails to trigger. I believe this is unintended behavior. The difference is that I am using a path for the variable a show below.
I think this should be allowed; if it is not allowed, the expressions should not be allowed.
  • n8n version: n8n@1.107.4
  • Running n8n via (Docker, npm, n8n cloud, desktop app): cloud
  • the nodes on your canvas and use the keyboard shortcuts CMD+C/CTRL+C and CMD+V/CTRL+V to copy and paste the workflow.)
  • Operating system: windows
hello @Jim_Olson
What is vars? You can’t chain anything to the webhook node as it should be the first node in a chain. However, you can access some ENV variables in it
I am using these global vars vars | n8n Docs
I don’t think it’s possible to dynamically set the path, as it should be registered once the workflow is active. What is the reason for it?
In that case, there should not be an expression option for that value. It is misleading.
You can submit a bug report on the github, so the issue will be tracked.
Issues · n8n-io/n8n
