Workflow running forever
I recently installed n8n on my domain and all the workflows run forever. It doesn´t matter wich trigger I select, it does the same. I tried with “Trigger manually” and “On form submission” but is the same.
  • **n8n version:*1.66.0
  • **Database (default: SQLite):default
  • **Running n8n via: Google Cloud - VM instance
  • **Operating system:Windows 11
  • **n8n version: 1.66.0
  • **Database (default: SQLite): SQLite
  • **n8n EXECUTIONS_PROCESS setting (default: own, main): None
  • **Running n8n via (Docker, npm, n8n cloud, desktop app): Google Cloud - VM instance
  • **Operating system: Windows 11
Hi @danschwab2002 ,
Welcome to the community! :icecream:
What message do you get in your logs when this happens?
There is no message. I have the same issue.
The Test workflow is just hanging forever with the spinner. Please check my earlier post on this same topic.
