Xero Connection Error
Hello, brand new to n8n so apologies if this is basic. I’m getting the following error message, when it feels like Xero has been connected properly. Help pls?
Forbidden - perhaps check your credentials?
403 - {“Type”:null,“Title”:“Forbidden”,“Status”:403,“Detail”:“AuthenticationUnsuccessful”,“Instance”:“eac8a33e-0d7d-4cbe-b61e-e212eaef40da”,“Extensions”:{}}
Here are the steps required to connect your Xero app to n8n:
  1. Create a Xero App from Developer Portal.
    • Type app name
    • Choose Web App
    • Copy Redirect URI from n8n and paste it below company URL.
  2. After creating the app go to Configuration page from left menu.
  3. Copy client ID, generate a Client Secret and paste both in n8n.
  4. Press Connect my account button and authorize. Make sure the authorization URL looks like this:
    https://login.xero.com/identity/connect/authorize?response_type=code&client_id=YOURCLIENTID&redirect_uri=YOURREDIRECTURI&scope=openid profile email accounting.transactions accounting.contacts&state=123
This should let you use Xero node in full functionality.
Hiya Mookie_Lian, I followed these steps which I had done previously but I still seem to have the same issue. Any ideas please?
