I’m moving nodes around, trying to make my flow look linear but every time I load it it’s messy again. I think that node position is not updated. I’ve tried making some change to node (add/delete) and save flow but after reload nodes are in ‘random’ positions. It’s not random, because it’s the same every time, but not what I saved.
Please share the workflow
n8n version:0.172.0
Database you’re using (default: SQLite): SQLite
Running n8n with the execution process [own(default), main]:
Running n8n via [Docker, npm, n8n.cloud, desktop app]:npm
Hello, are you by any chance using tablet or touch screen? Because that’s a known issue for those platforms. I did a quick test on latest Chrome, Firefox and Safari and I cannot reproduce. Which browser and what version of that are you using so I can try to reproduce? Did you not experience this in previous versions?
I’m using laptop with a touch screen, but I don’t use it to set up a workflow. Instead I use mouse.
I think that there was no issue on previous version (170).
