Problems with Python code node in n8n
Hello!
I got the error in my n8n workflow on code node (I used python):
Error: Task request timed out after 60 seconds at LocalTaskRequester.requestExpired (/usr/local/lib/node_modules/n8n/src/task-runners/task-managers/task-requester.ts:304:17) at LocalTaskRequester.onMessage (/usr/local/lib/node_modules/n8n/src/task-runners/task-managers/task-requester.ts:272:10) at TaskBroker.handleRequestTimeout (/usr/local/lib/node_modules/n8n/src/task-runners/task-broker/task-broker.service.ts:124:50) at Timeout. (/usr/local/lib/node_modules/n8n/src/task-runners/task-broker/task-broker.service.ts:110:9) at listOnTimeout (node:internal/timers:605:17) at processTimers (node:internal/timers:541:7)
My code:
snippet_text = _items[0]["json"]["snippet"]
return [{'json': {'snippet': snippet_text}}]
I launch n8n via docker compose.
Here my docker compose config:
services:
  n8n:
    image: n8nio/n8n:latest
    container_name: n8n-main
    restart: always
    environment:
      - N8N_ENFORCE_SETTINGS_FILE_PERMISSIONS=false
      - N8N_BLOCK_ENV_ACCESS_IN_NODE=false
      - N8N_HOST=://example.com
      - N8N_PORT=5678
      - WEBHOOK_URL=http://localhost:5678/
      - DB_TYPE=postgresdb
      - DB_POSTGRESDB_HOST=postgres
      - DB_POSTGRESDB_PORT=5432
      - DB_POSTGRESDB_DATABASE=n8n
      - DB_POSTGRESDB_USER=n8n_user
      - DB_POSTGRESDB_PASSWORD=your_postgres_password
      - N8N_RUNNERS_ENABLED=true
      - N8N_RUNNERS_MODE=external
      - N8N_RUNNERS_AUTH_TOKEN=super_secure_token_change_me
      - N8N_RUNNERS_BROKER_PORT=5679
      - N8N_RUNNERS_BROKER_LISTEN_ADDRESS=0.0.0.0
    ports:
      - "5678:5678"
      - "5679:5679"
    volumes:
      - n8n_data:/home/node/.n8n
    depends_on:
      postgres:
        condition: service_healthy
  n8n-runner:
    image: n8nio/runners:latest
    container_name: n8n-task-runner
    restart: always
    environment:
    - N8N_RUNNERS_ENABLED_MODES=python
      - N8N_RUNNERS_BROKER_URL=ws://n8n:5679
    depends_on:
      - n8n
  postgres:
    image: postgres:15-alpine
    container_name: n8n-postgres
    restart: always
    environment:
      - POSTGRES_USER=n8n_user
      - POSTGRES_PASSWORD=your_postgres_password
      - POSTGRES_DB=n8n
    volumes:
      - postgres_data:/var/lib/postgresql/data
    healthcheck:
      test: \["CMD-SHELL", "pg_isready -U n8n_user -d n8n"\]
      interval: 5s
      timeout: 5s
      retries: 5
volumes:
  n8n_data:
  postgres_data:
How I can fix that?
Thanks in advance!
Welcome @Quent!
Your runner service has two wrong environment variable names that cause the timeout. Replace N8N_RUNNERS_BROKER_URL with N8N_RUNNERS_TASK_BROKER_URI=http://n8n:5679, and replace N8N_RUNNERS_ENABLED_MODES with N8N_RUNNERS_ENABLED_TASK_TYPES=javascript,python. Also fix the YAML indentation in your runner’s environment block - all items need consistent leading spaces. Here’s the corrected n8n-runner service:
n8n-runner:
restart: always
environment:
  • N8N_RUNNERS_ENABLED_TASK_TYPES=javascript,python
  • N8N_RUNNERS_TASK_BROKER_URI=http://n8n:5679
  • N8N_RUNNERS_AUTH_TOKEN=super_secure_token_change_me
    depends_on:
  • n8n
After updating, run docker compose down && docker compose up -d. If timeouts still happen, you can add N8N_RUNNERS_TASK_REQUEST_TIMEOUT=120 to the n8n service environment to give the runner more time.
Thank you!
