Can't Connect to Bubble - Very Basic Issue from Newbie
Can’t Connect to Bubble.
I tried all different types of credentials (live/dev and self hosted and bubble) including the bubbleapps url and the hosted domain url (the root and the whole thing)
and the Data API is enabled and there are no privacy rules but not matter what I try to do (create, get) I get a error where Bubble sends back all the app page data and plugins etc but not the actual object.
error message EDITED
The resource you are requesting could not be found
404 - {“page_name”:“404”,“assets”:{“css”:[“/package/run_css/733e70b686f906b12808acdd84bdac089bc7afbcd39fa452bb434f3e51816251/ares-19041/live/404/xfalse/xfalse/run.css”],“js”:
NodeApiError: The resource you are requesting could not be found at ExecuteContext.bubbleApiRequest (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Bubble/GenericFunctions.js:32:15) at processTicksAndRejections (node:internal/process/task_queues:95:5) at ExecuteContext.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Bubble/Bubble.node.js:112:40) at WorkflowExecute.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:632:19) at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:872:51 at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:1206:20
n8n Settings
  • n8n version: 1.74.1 (Cloud)
  • Node type: n8n-nodes-base.bubble
  • Database (default: SQLite): ?? IDK but didnt touch this
  • n8n EXECUTIONS_PROCESS setting (default: own, main): ?? IDK but didnt touch this
  • Running n8n via (Docker, npm, n8n cloud, desktop app): cloud
  • Operating system: Windows 10 Pro but using cloud??
Thanks. updated as much as I could. Wow this seems like it’s way overcomplicated to debug or get help (this coming from a decade of experience in traditinoal code enviroments).
