Does n8n work smoothly at all?
Im having a problem where my Google docs doenst connect with the n8n while my If my Google OAuth client credentials are set . Linkedin node is another issue. However, I was scrolling this forum and the last 24 hours I see around 50 people posted about issues. Is this working smoothly at all? Im new here so, sorry for the rant.
I have not had issues with Google APIs (including Gmail, Drive, and Docs). I even re-created a credential. That is not to say it could be down for some people and maybe you should try again later?
Either way, I was successful today and you can check out this article where I posted instructions:
I hope this helps. -Bill
Bill, thanks so much for the reply. I will try now.
