Hey guys, I have a problem on a client’s server, after I upgraded his server on digital ocean, it started to stop showing the execution data, it just keeps showing the loading icon infinitely, is there any variable to fix this?
is there any way to fix this?
Sorry to hear that you have problems but can you please fill out the issue template we created instead of deleting it? We added it for a reason, and the reason is that it contains important information to be able to help people with their problems. Thanks a lot!
Hey @jan, follow the info
after i updated the client server on digital ocean, it started to stop showing the execution data, it just keeps showing the loading icon infinitely
none, it just doesn’t show the execution data
Are in all workflows
n8n version:
Version 0.222.3 -
Database (default: SQLite):
Default -
own -
Docker-Compose -
Operating system:
Ubuntu 20.04 (LTS) x64
Thanks! You are on a quite an old version. There have been some fixes in recent versions, and even more fixes in the version that will be released next week. You can for now try 0.226.0 and see if that fixes your issues. Would be great if you could report back if you still have the issue on that version.
