Editor preview shows wrong data (wrong node's output)
Editor preview doesn’t display the correct data.
It displays the data from the last node, instead of the node being targeted, when using something like: {{ $('Prepare data: Create Activity Note').item.json }}.
  • n8n version: 1.53.2
  • n8n EXECUTIONS_PROCESS setting (default: own, main): Unsure
  • Running n8n via (Docker, npm, n8n cloud, desktop app): Docker (Cloudron)
  • Operating system: Ubuntu 22.04
hello @Vadorequest
Have you tried to use Execute workflow button instead of using the test step one? It sometimes gets buggy when there is a pinned data just before the node you are testing
