I got this error when trying to use Execute Workflow to run other workflows, my current plan is FREE, and looks like it can’t use this node, I wanna know if we have another solution for this?
I’m just having an idea about Webhook Node (Resources for this gonna very high if I have 4-5 workflows are listening on the same time)
"errorMessage": "The service was not able to process your request",
"errorDetails": {},
"n8nDetails": {
"nodeName": "HTTP Request",
"nodeType": "n8n-nodes-base.httpRequest",
"nodeVersion": 4.1,
"time": "3/27/2024, 11:48:30 AM",
"n8nVersion": "1.33.1 (Self Hosted)",
"binaryDataMode": "default",
"stackTrace": [
"NodeApiError: The service was not able to process your request",
" at Object.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/HttpRequest/V3/HttpRequestV3.node.js:1571:35)",
" at processTicksAndRejections (node:internal/process/task_queues:95:5)",
" at Workflow.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Workflow.js:724:19)",
" at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:660:53",
" at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:1062:20"
