'Get Many Workflows' Node Help
n8n beginner here:
I added a ‘Get many workflows’ n8n node and I want to specifically just get two workflows (One named ‘Part Time Job Tracker’ and another named ‘Workflow 1’. I went to ‘Filters’, then ‘Names’, and simply added the two workflow names separated by a comma like this:
I was wondering what the best way to specify these two workflows would be, should I use tags instead?
If the Names filter supports multiple values, try adding each workflow name as a separate value rather than entering both names as one comma-separated string.
If it only accepts a single name, you can run two separate Get Many Workflows requests and merge the results afterward.
Tags are useful when you want to retrieve workflows based on shared categories, but for these two specific workflows, filtering by their exact names is more appropriate.
Also, check whether the node returns an exact match or partial match for the Names filter.
Hi @Josue_Vazquez, yes, I’d use a shared tag for this pair. Add a tag such as selected-workflows to Part Time Job Tracker and Workflow 1, and only those two. In Get Many, remove the Name filter, add Filters → Tags, and enter selected-workflows. Keep Return All on.
The Name field sends your whole comma-separated text as one name value. Using a shared tag also keeps this selection working if you rename either workflow. Run the node and check that those two workflows are returned.
A comma-separated name list probably won’t match, since the name filter looks for one string. Tags are the cleaner way: tag both workflows with something like tracker, then filter by that tag. Otherwise pull everything and add a Filter node after it checking the name equals either of the two. Tags hold up better if you add more later.
