Hi,
We’re experiencing persistent timeout errors when our workflow tries to make HTTP requests to a specific external API server at IP 178.250.246.39 (domain: wb.apisystem.name, port 80).
All requests from our n8n Cloud instance (IP 51.116.119.77) to this server result in timeout of 15000ms exceeded (ECONNABORTED). This has been happening since March 10, ~14:00 UTC.
At the same time, requests from the same workflow to other external APIs (e.g., Yandex Market via the same API provider but different server IP) work fine.
The API provider confirmed there is no block on their side and suggested we check if outbound traffic from our n8n instance to 178.250.246.39 might be blocked at the network/firewall level.
Could you please check if there are any network restrictions blocking outbound connections from our instance to IP 178.250.246.39?
Our instance: ingalove.app.n8n.cloud Workflow ID: 2e2Bpkhlvm69cIzs Recent failed execution: #741
Thank you!
