I have a question about the CRON Trigger node.
I defined a cron trigger to run at 4am in the morning. I setup the process to be active. N8N runs in as a docker application on a server with an external database.
I expected the CRON to run at 4 am in the morning, but it did not run, instead I had to start the workflow manually to then run. The parameters I chose were for it to run Daily and at 4 hours
see below the snipped:
"nodes": [
"parameters": {
"triggerTimes": {
"item": [
"hour": 4
"name": "4am in the morning",
"type": "n8n-nodes-base.cron",
"typeVersion": 1,
"position": [
380,
430
"parameters": {
"functionCode": "const todaysDate = new Date();\nconst todaysDateFormatted = `${todaysDate.getFullYear()}-${todaysDate.getMonth()+1}-${todaysDate.getDate()}`;\n\nconst yesterdaysDate = new Date(todaysDate.setDate(todaysDate.getDate() - 1));\nconst yesterdaysDateFormatted = `${yesterdaysDate.getFullYear()}-${yesterdaysDate.getMonth()+1}-${yesterdaysDate.getDate()}`;\n\n\nitems[0].json['start'] = yesterdaysDateFormatted;\nitems[0].json['end'] = todaysDateFormatted;\nreturn items;"
"name": "Function",
"typeVersion": 1,
"position": [
570,
430
"parameters": {
"requestMethod": "POST",
"url": "__some_url__",
"options": {},
"bodyParametersUi": {
"parameter": [
"name": "start",
"value": "={{$node[\"Function\"].data[\"start\"]}}"
"name": "end",
"value": "={{$node[\"Function\"].data[\"end\"]}}"
"queryParametersUi": {
"parameter": []
"name": "HTTP Request",
"typeVersion": 1,
"position": [
770,
430
"connections": {
"4am in the morning": {
"main": [
"node": "Function",
"type": "main",
"index": 0
"Function": {
"main": [
"node": "HTTP Request",
"type": "main",
"index": 0
What am I not getting?
