a mysql query is performed. The IF node checks whether the ouput contains ‘error’ key-value pair. (if not empty). The result is both false and true even though ‘execute once’ is enabled
n/a
Please share the workflow
(Select the nodes and use the keyboard shortcuts CMD+C/CTRL+C and CMD+V/CTRL+V to copy and paste the workflow respectively)
"meta": {
"instanceId": "f683212333b2b3d67d8731ecb37a5c2770b18016c107263ea7213119c03068ef"
"nodes": [
"parameters": {
"httpMethod": "POST",
"path": "/v1/gxsessions",
"responseMode": "responseNode",
"options": {
"rawBody": false
"id": "5c52d05d-8f97-42ce-a832-cbb097ea029a",
"name": "Webhook",
"type": "n8n-nodes-base.webhook",
"typeVersion": 1,
"position": [
-100,
340
"webhookId": "ddad8189-da17-4a39-813f-ab8cc83d1983",
"notesInFlow": true,
"notes": "receive POST /v1/gxsessions"
"parameters": {
"respondWith": "json",
"responseBody": "={ \"session_id\" : \"{{$node[\"Webhook\"].json[\"body\"][\"session_id\"]}}\", \"result_code\" : 4001 }",
"options": {
"responseCode": 500
"id": "331aeac1-cb1b-4b04-9e07-6873ca8e7277",
"name": "Respond to Webhook",
"type": "n8n-nodes-base.respondToWebhook",
"typeVersion": 1,
"position": [
900,
80
"alwaysOutputData": true,
"executeOnce": true,
"continueOnFail": true,
"notes": "return error response"
"parameters": {
"operation": "executeQuery",
"query": "=insert\ninto pcrfmgmt.gxsessions\n(\nsession_id ,\nframed_ipv6_prefix,\nframed_ip_address,\ncalled_station_id,\nsubscription_id_data_0,\nsubscription_id_data_1,\n3gpp_sgsn_mcc_mnc,\ncc_request_type,\ncc_request_number,\norigin_host,\norigin_realm,\ndestination_host,\ndestination_realm,\nauth_application_id,\nsupported_features_list_id,\nsupported_features_list_flags,\nbearer_usage,\norigin_state_id,\nnetwork_request_support,\nip_can_type,\nrat_type,\nuser_equipment_info_type,\nuser_equipment_info_value,\nqos_information_qos_class_identifier,\nqos_information_max_requested_bandwidth_ul,\nqos_information_max_requested_bandwidth_dl,\nqos_information_guaranteed_bitrate_ul,\nqos_information_guaranteed_bitrate_dl,\nqos_information_bearer_identifier,\nqos_information_apn_aggregate_max_bitrate_ul,\nqos_information_apn_aggregate_max_bitrate_dl,\ndefault_eps_bearer_qos_qos_class_identifier,\ndefault_eps_bearer_qos_arp_priority_level,\ndefault_eps_bearer_qos_arp_pre_emption_capability,\ndefault_eps_bearer_qos_arp_pre_emption_vulnerability,\nan_gw_address,\n3gpp_user_location_info_tai,\n3gpp_user_location_info_ecgi,\n3gpp_ms_timezone,\nonline,\naccess_network_charging_address,\naccess_network_charging_identifier_gx_value,\n3gpp_charging_characteristics\n)\nvalues\n(\n'{{$json[\"body\"][\"session_id\"]}}',\n'{{$json[\"body\"][\"framed_ipv6_prefix\"]}}',\n'{{$json[\"body\"][\"framed_ip_address\"]}}',\n'{{$json[\"body\"][\"called_station_id\"]}}',\n'{{$json[\"body\"][\"subscription_id_data_0\"]}}',\n'{{$json[\"body\"][\"subscription_id_data_1\"]}}',\n'{{$json[\"body\"][\"3gpp_sgsn_mcc_mnc\"]}}',\n'{{$json[\"body\"][\"cc_request_type\"]}}',\n'{{$json[\"body\"][\"cc_request_number\"]}}',\n'{{$json[\"body\"][\"origin_host\"]}}',\n'{{$json[\"body\"][\"origin_realm\"]}}',\n'{{$json[\"body\"][\"destination_host\"]}}',\n'{{$json[\"body\"][\"destination_realm\"]}}',\n'{{$json[\"body\"][\"auth_application_id\"]}}',\n'{{$json[\"body\"][\"supported_features_list_id\"]}}',\n'{{$json[\"body\"][\"supported_features_list_flags\"]}}',\n'{{$json[\"body\"][\"bearer_usage\"]}}',\n'{{$json[\"body\"][\"origin_state_id\"]}}',\n'{{$json[\"body\"][\"network_request_support\"]}}',\n'{{$json[\"body\"][\"ip_can_type\"]}}',\n'{{$json[\"body\"][\"rat_type\"]}}',\n'{{$json[\"body\"][\"user_equipment_info_type\"]}}',\n'{{$json[\"body\"][\"user_equipment_info_value\"]}}',\n'{{$json[\"body\"][\"qos_information_qos_class_identifier\"]}}',\n'{{$json[\"body\"][\"qos_information_max_requested_bandwidth_ul\"]}}',\n'{{$json[\"body\"][\"qos_information_max_requested_bandwidth_dl\"]}}',\n'{{$json[\"body\"][\"qos_information_guaranteed_bitrate_ul\"]}}',\n'{{$json[\"body\"][\"qos_information_guaranteed_bitrate_dl\"]}}',\n'{{$json[\"body\"][\"qos_information_bearer_identifier\"]}}',\n'{{$json[\"body\"][\"qos_information_apn_aggregate_max_bitrate_ul\"]}}',\n'{{$json[\"body\"][\"qos_information_apn_aggregate_max_bitrate_dl\"]}}',\n'{{$json[\"body\"][\"default_eps_bearer_qos_qos_class_identifier\"]}}',\n'{{$json[\"body\"][\"default_eps_bearer_qos_arp_priority_level\"]}}',\n'{{$json[\"body\"][\"default_eps_bearer_qos_arp_pre_emption_capability\"]}}',\n'{{$json[\"body\"][\"default_eps_bearer_qos_arp_pre_emption_vulnerability\"]}}',\n'{{$json[\"body\"][\"an_gw_address\"]}}',\n'{{$json[\"body\"][\"3gpp_user_location_info_tai\"]}}',\n'{{$json[\"body\"][\"3gpp_user_location_info_ecgi\"]}}',\n'{{$json[\"body\"][\"3gpp_ms_timezone\"]}}',\n'{{$json[\"body\"][\"online\"]}}',\n'{{$json[\"body\"][\"access_network_charging_address\"]}}',\n'{{$json[\"body\"][\"access_network_charging_identifier_gx_value\"]}}',\n'{{$json[\"body\"][\"3gpp_charging_characteristics\"]}}'\n)"
"id": "10444feb-008f-4a0d-a79a-7ccd27695d13",
"name": "MySQL",
"type": "n8n-nodes-base.mySql",
"typeVersion": 1,
"position": [
240,
340
"credentials": {
"mySql": {
"id": "1",
"name": "MySQL account"
"notes": "store Gx session"
"parameters": {
"conditions": {
"string": [
"value1": "={{$json[\"error\"]}}",
"operation": "isNotEmpty"
"id": "8bc94f53-1c4a-44a5-b32b-9c651a0f26ad",
"name": "IF",
"type": "n8n-nodes-base.if",
"typeVersion": 1,
"position": [
480,
340
"notes": "if not stored"
"parameters": {
"responseBody": "={ \"session_id\" : \"{{$node[\"Webhook\"].json[\"body\"][\"session_id\"]}}\", \"result_code\" : 2001 }",
"options": {
"responseCode": 200
"id": "290a37da-2673-4acd-8fc5-fc622a6780e0",
"name": "Respond to Webhook1",
"typeVersion": 1,
"position": [
900,
400
"notes": "return success"
"connections": {
"Webhook": {
"main": [
"node": "MySQL",
"type": "main",
"index": 0
"MySQL": {
"main": [
"node": "IF",
"type": "main",
"index": 0
"IF": {
"main": [
"node": "Respond to Webhook",
"type": "main",
"index": 0
"node": "Respond to Webhook1",
"type": "main",
"index": 0
## Share the output returned by the last node
<!-- If you need help with transforming the data, please also share the expected output -->
- **n8n version:**0.202.1
- **Database you're using (default: SQLite):**sqlite
- **Running n8n with the execution process [own(default), main]:**
- **Running n8n via [Docker, npm, n8n.cloud, desktop app]:**docker
