Importing external module does not work no matter what
Hello!
I want to use external module named “mailparser” inside the “code node”. But I get the error ERROR: Cannot find module ‘mailparser’ [line 1] VMError. I am running n8n on npm. I installed npm using NVM. I installed the “mailparser” module in the $HOME/.nvm/versions/node/v18.14.0/lib/node_modules/n8n directory(using npm install mailparser --save) and globally(using npmm install -g mailparser). And then executed export NODE_FUNCTION_ALLOW_BUILTIN=* and export NODE_FUNCTION_ALLOW_EXTERNAL=*. Even then it is giving me the error. What should I do ?
I’m running n8n Version: 0.215.1 on npm.
Thanks.
Hey @Rusiru_Sadathana,
Welcome to the community :raised_hands:
I have just done a quick test on my local n8n instance and as we already use mailparser in my Code node just using the below works with no errors.
const mp = require('mailparser');
return $input.all();
I have NODE_FUNCTION_ALLOW_BUILTIN and NODE_FUNCTION_ALLOW_EXTERNAL both set to * could be worth checking that and maybe using Node v16 as well which is the officially supported version.
