Why do you have a GUI different than the available there? The field is supposed to list all the posible assignees? Am I missing something? When you execute the node, you get an error? If not, ignore the warning message.
At a start i have a list like you said.
But i wanna use a variable with GID there.
When i use it i got this error:
As you can see my variable contains GID but somehow n8n throw a error.
The only thing that comes to mind it’s that id it’s not a valid user id. Where is this ID coming from? is it coming from a webhook? What node is referencing the expression?
Thanks Jan!
I didn’t think about it.
Google Sheets changed format to text and i don’t know why.
Good to know that there is function to check it: TYPE - Docs Editors Help
