Tasik
March 14, 2025, 2:08pm
1
Issues:
The value “9” is not supported! I can’t substitute any value, I tried 9am, 09**1, everywhere the same error that the value is not supported. The current time is displayed just like on a computer
What is the error message
n8n version: 1.82.0
Database (default: SQLite):
Running n8n via (n8n-production-3f03.up.railway.app)):
Operating system: Windows 10
Change the field to FIXED:
If my reply answers your question, please remember to mark it as a solution.
Tasik
March 14, 2025, 2:43pm
3
Unfortunately for me, it looks like this
Even when you copy the node I provided above?
Tasik
March 14, 2025, 3:02pm
5
After copying your node, the same problem persists
Can you try the following?
restarting your instance
try an older version (1.81.4 would be good)
This might be a bug. Let’s try to find out if this is exclusive to your instance or if it’s a version issue.
Tasik
March 14, 2025, 3:36pm
7
Solomon / Salomão:
1.81.4
I ran the n8n locally, everything works there.
Awesome. So it’s an issue with your setup.
Try reinstalling it or restarting
