I’m trying to build an AI Agent in n8n that can fetch order information from Shopify via a GraphQL query. The agent is integrated with Slack, and it communicates with a n8n MCP server in another workflow.
The tool I’m using getSubscriptionRetailValue is supposed to pass an orderID as a parameter to a GraphQL node, which looks like this:
query getOrder($orderID: String!) {
order(id: $orderID) {
currentSubtotalLineItemsQuantity
lineItems(first: 10) {
edges {
node {
name
originalUnitPriceSet {
presentmentMoney {
amount
The variable field is configured as “Defined automatically by the model”
When the Agent node calls the MCP client, I get the following error in MCP client:
Failed to execute tool "getSubscriptionRetailValue"
Error: Received tool input did not match expected schema
However, the log shows the input seems valid:
"query": {
"orderID": "gid://shopify/Order/43xxxxxx23"
"tool": {
"name": "getSubscriptionRetailValue",
"description": "Retrieve the retail value of the products included in an order from an order id. Use the order id from a new subscription as a parameter\nKeyword to be used to provide the order id is the following \"orderID\"\nThis orderID must follow this format \"gid://shopify/Order/47xxxxx54\""
How can I resolve this schema mismatch?
Is there a specific format or schema declaration I need to apply for the orderID parameter inside the Agent tool or the MCP server workflow?
Thanks in advance!
- n8n version: Cloud version n8n@1.99.1
- Running n8n via (Docker, npm, n8n cloud, desktop app): n8n cloud
