Hello everyone
How can I transfer data between the tools of an agent?
For example, I have 2 tools and would like to send the data to the second request after the first request is completed.
My Flow:
Hello everyone
My Flow:
Hi @Silvio_Brito ,
Unfortunately, this isn’t really a possibility at the moment. Tools can’t directly access other tool’s outputs.
You might be able to work around it by storing the first tool’s output in a database and ensuring the Agent knows to call the second tool accordingly. But this is not tested.
there is not really an easy way right now, I think. you would need to store it in a database, and make sure the LLM knows to call the other tool; but that will probably be very tricky to get working in any case.
