[N8N & BASEROW] Excessive Processing Delay in my n8n HR Data Insertion Process in Baserow
Hello Team,
I am encountering a major issue with my n8n process, which involves inserting data from HR source files into a Baserow database. The process includes extracting data from an Excel file, inserting it into Baserow, and initiating a process that generates an automatic report with qualitative and quantitative statistics on this data.
The challenge I’m facing is the excessive processing time of this workflow, particularly at the dataset level. Currently, the execution takes about two days, which is clearly abnormal. However, the structure of the table in Baserow is somewhat complex: it retrieves field names and value types, inserting each column as a separate row, with another pivot table to link rows and columns.
I have analyzed the n8n script and Baserow configuration, but I cannot identify the source of the problem. I suspect that the issue lies either in my platform or in the process itself.
Do you have any suggestions for optimizing this process and significantly reducing the execution time at the dataset level? Any expertise would be greatly appreciated.
Thank you in advance for your assistance!
Here are my configurations:
.env
QUEUE_BULL_REDIS_HOST=redis
COMPOSE_HTTP_TIMEOUT=3600
Set the logging level to ‘debug’
N8N_LOG_LEVEL=debug
Set log output to both console
N8N_LOG_OUTPUT=console
Set a 50 MB maximum size for each log file
N8N_LOG_FILE_MAXSIZE=500
EXECUTIONS_DATA_SAVE_ON_ERROR=all
EXECUTIONS_DATA_SAVE_ON_PROGRESS=false
EXECUTIONS_DATA_SAVE_ON_SUCCESS=none
EXECUTIONS_DATA_SAVE_MANUAL_EXECUTIONS=false
EXECUTIONS_DATA_PRUNE=true
EXECUTIONS_DATA_MAX_AGE=168
EXECUTIONS_DATA_PRUNE_MAX_COUNT=50000
EXECUTIONS_TIMEOUT=-1
NODE_OPTIONS=“–max-old-space-size=22528”
docker-compose.yml
version: ‘3.1’
services:
postgres:
image: postgres:11
container_name: postgres
restart: always
ports:
5435:5432
env_file:
.env
volumes:
/opt/n8n-XXX/data/database/postgresql:/var/lib/postgresql/data
networks:
servernet
redis:
image: redis:6-alpine
container_name: redis
restart: always
volumes:
redis_storage:/data
healthcheck:
test: [“CMD”, “redis-cli”, “ping”]
interval: 5s
timeout: 20s
retries: 10
mongo:
image: mongo:4.4
env_file:
.env
ports:
“27018:27017”
networks:
servernet
volumes:
my-mongo-volume:/data
n8n:
image: n8nio/n8n:1.15.2
labels:
io.portainer.accesscontrol.teams=developpement
restart: always
env_file:
.env
ports:
5678:5678
extra_hosts:
“DNS.XXX.XXX:IP.XX.XXX.XXX”
links:
postgres
redis
mongo
labels:
traefik.enable=true
traefik.http.routers.n8n.rule=Host(${SUBDOMAIN}.${DOMAIN_NAME})
traefik.http.routers.n8n.tls=true
traefik.http.routers.n8n.entrypoints=web,websecure
traefik.http.routers.n8n.tls.certresolver=mytlschallenge
traefik.http.middlewares.n8n.headers.SSLRedirect=true
traefik.http.middlewares.n8n.headers.STSSeconds=315360000
traefik.http.middlewares.n8n.headers.browserXSSFilter=true
traefik.http.middlewares.n8n.headers.contentTypeNosniff=true
traefik.http.middlewares.n8n.headers.forceSTSHeader=true
traefik.http.middlewares.n8n.headers.SSLHost=${DOMAIN_NAME}
traefik.http.middlewares.n8n.headers.STSIncludeSubdomains=true
traefik.http.middlewares.n8n.headers.STSPreload=true
traefik.http.routers.n8n.middlewares=n8n@docker
volumes:
/opt/n8n_XX:/home/node/
/opt/sftp-n8n/data/uploads:/home/data
command: “start”
depends_on:
postgres
redis
mongo
networks:
servernet
networks:
servernet:
driver: bridge
volumes:
n8n_storage:
redis_storage:
my-mongo-volume:
external: false
  • **n8n version: 1.15.2
  • **Database (default: SQLite): mongoDB, postgres
  • **third-party database: Baserow
  • **Running n8n via (Docker, npm, n8n cloud, desktop app): Docker
  • **Operating system: RedHat Linux serveur
Hey @Micka_Rakotomalala,
Are you always running this workflow from the UI with the execute button or do you have it scheduled as that can also impact the speed.
One thing I would maybe do is break that workflow up into smaller workflows then use the execute workflow options so that you can make the most of the workers if you are using them.
Hi @Jon
Thank you very much for your feedback
Eventually, when we deliver to production, we’re going to plan with a trigger that will be triggered in the background every week.
The old version of dataset is separated by independent workflows, however if I retrieve a file of 6800 lines in the database, it takes a long time, even several minutes, it seemed that it even crashes.
So maybe I need to split the files too, or not?
That’s why I put the switch by company there, but it’s frozen. What other option is there for retrieving a large list from a node?
on a baserow node, to retrieve 29 lines, is it normal that it takes 35 seconds to obtain 29 lines of data in baserow?
I have a redhat server, which hosts baserow and n8n in the same server separated just by containers. Is it a good idea to put them together?
Just for test
35 seconds is a long time, On my setup of n8n and Baserow both in different containers it is taking under 3 seconds to get 468 items although this is only 10 columns so I suspect if you have a lot more it will take longer.
Have you done a test against the Baserow cloud offering to see if that is also slow?
Hi @Jon
On the other hand, it’s just two baserow nodes that I’m using, so it shouldn’t cause 2 days of execution if it’s 28 seconds to access, because afterwards I used http request node for batch insertion of the element into the database.
Locally, I tested with baserow cloud, it was fast, about 2 seconds. However, I don’t have access to baserow cloud on my server.
Is using several code nodes also a problem for this process?
Hi @Micka_Rakotomalala,
The code nodes are likely to be ok, It sounds like if it is 2 seconds using Cloud and 28 seconds locally there is something local in your environment causing a delay.
Could your server be overloaded or maybe something like SELinux is getting in the way?
Thanks for your help, I’ll check with the teams for the operating system configuration and investigate server side, but for network flows it’s open to everything and no specific blocking, Cloudflare for security then reverse proxy to access via url.
Just one question: given the load, which is set to increase still further, with both projects on the same server, can we use docker swarm for docker installation of n8n?
If you are comfortable using Docker Swarm you should be able to use it, We don’t have any guides on that and as an advanced deployment option you would need to rely on the skills of your team to maintain and deploy it.
Out of interest are you connecting to your Baserow instance directly or are you using the url and going through cloudflare?
Hey @Jon
I used to connect with n8n’s baserow node, but I compared the latency between baserow node and http request so I changed to http request via url passed through cloudflare.
Sucuri is replaced by cloudflare, an older architecture
And also how do you connect directly to baserow in n8n, I’ve used the baserow IP but it doesn’t work either with baserow nodes or with http request?
I would recommend getting the IP working as there is no sense in using the URL and possibly routing the traffic outside of your network then back in to make the call unless you have your local DNS configured to keep the traffic internal to you.
I don’t understand, I configured my url just by my IP and port, IP baserow and equal to IP n8n, differentiate just by ports, but I can’t get the tables in baserow? should I add the ip in docker-compose like this :
n8n_image:
extra_hosts:
- “baserow.pulse.mg:101.X.X.X”
And also I’ve already optimized my process, limited the logs, inserted the entries with the number of rows in entries to the number of rows inserted in the base, it still took more than 5 hours my process.
There’s the limitation of nodes and scripts.
For the rest of the investigation, other than the direct database connection, I don’t know what else to do to limit my process execution time.
would limiting the size of log writes on the docker have any impact on n8n?
2023-11-20T13:45:49.905Z | debug | Executing hook on node “Value splitInBatch1” (hookFunctionsPush) “{\n executionId: ‘32171’,\n sessionId: ‘ie7oh93hzg’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘nodeExecuteAfter’\n}”
2023-11-20T13:45:49.905Z | error | The session “ie7oh93hzg” is not registered. “{ sessionId: ‘ie7oh93hzg’, file: ‘abstract.push.js’, function: ‘send’ }”
2023-11-20T13:45:49.905Z | debug | Save execution progress to database for execution ID 32171 “{\n executionId: ‘32171’,\n nodeName: ‘Value splitInBatch1’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘nodeExecuteAfter’\n}”
2023-11-20T13:45:49.942Z | debug | Proxying request to axios “{ file: ‘LoggerProxy.js’, function: ‘exports.debug’ }”
2023-11-20T13:45:50.399Z | debug | Running node “GET Raw Batch1” finished with error “{\n node: ‘GET Raw Batch1’,\n workflowId: ‘qkp1ObK2jApdiSDp’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.debug’\n}”
2023-11-20T13:46:28.878Z | debug | Running node “GET Raw Batch1” started “{\n node: ‘GET Raw Batch1’,\n workflowId: ‘qkp1ObK2jApdiSDp’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.debug’\n}”
2023-11-20T13:46:28.882Z [Rudder] debug: no existing flush timer, creating new one
2023-11-20T13:46:28.924Z | debug | Add editor-UI session “{ sessionId: ‘qv7sg3f0k4b’, file: ‘abstract.push.js’, function: ‘add’ }”
2023-11-20T13:46:44.564Z | debug | Start processing node “Switch” “{\n node: ‘Switch’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.debug’\n}”
11-20T13:46:44.565Z | debug | Executing hook on node “Switch” (hookFunctionsPush) “{\n executionId: ‘32171’,\n sessionId: ‘ie7oh93hzg’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘nodeExecuteBefore’\n}”
2023-11-20T13:46:44.566Z | error | The session “ie7oh93hzg” is not registered. “{ sessionId: ‘ie7oh93hzg’, file: ‘abstract.push.js’, function: ‘send’ }”
2023-11-20T13:46:44.566Z | debug | Running node “Switch” started “{\n node: ‘Switch’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.debug’\n}”
2023-11-20T13:46:44.568Z | debug | Running node “Switch” finished successfully “{\n node: ‘Switch’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.debug’\n}”
2023-11-20T13:46:44.569Z | debug | Executing hook on node “Switch” (hookFunctionsPush) “{\n executionId: ‘32171’,\n sessionId: ‘ie7oh93hzg’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘nodeExecuteAfter’\n}”
2023-11-20T13:46:44.569Z | error | The session “ie7oh93hzg” is not registered. “{ sessionId: ‘ie7oh93hzg’, file: ‘abstract.push.js’, function: ‘send’ }”
2023-11-20T13:46:44.569Z | debug | Save execution progress to database for execution ID 32171 “{\n executionId: ‘32171’,\n nodeName: ‘Switch’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘nodeExecuteAfter’\n}”
2023-11-20T13:46:44.585Z | debug | Found no executions to hard-delete (pruning cycle) “{ file: ‘pruning.service.js’, function: ‘hardDeleteOnPruningCycle’ }”
2023-11-20T13:46:44.586Z | debug | Scheduling hard-deletion for next 15.00 min (pruning cycle) “{ file: ‘pruning.service.js’, function: ‘scheduleHardDeletion’ }”
2023-11-20T13:46:44.589Z | debug | Proxying request to axios “{ file: ‘LoggerProxy.js’, function: ‘exports.debug’ }”
2023-11-20T13:46:44.604Z | debug | Running node “GET Raw Batch1” finished with error “{\n node: ‘GET Raw Batch1’,\n workflowId: ‘qkp1ObK2jApdiSDp’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.debug’\n}”
2023-11-20T13:47:25.270Z | debug | Running node “GET Raw Batch1” started “{\n node: ‘GET Raw Batch1’,\n workflowId: ‘qkp1ObK2jApdiSDp’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.debug’\n}”
2023-11-20T13:47:25.271Z [Rudder] debug: in flush
2023-11-20T13:47:25.271Z [Rudder] debug: cancelling existing timer…
2023-11-20T13:47:25.271Z [Rudder] debug: cancelling existing flushTimer…
2023-11-20T13:47:25.271Z [Rudder] debug: batch size is 4
2023-11-20T13:47:25.274Z | debug | Wait tracker querying database for waiting executions “{ file: ‘WaitTracker.js’, function: ‘getWaitingExecutions’ }”
2023-11-20T13:47:42.050Z | debug | Start processing node “Loop Over Items9” “{\n node: ‘Loop Over Items9’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.debug’\n}”
2023-11-20T13:47:42.051Z | debug | Executing hook on node “Loop Over Items9” (hookFunctionsPush) “{\n executionId: ‘32171’,\n sessionId: ‘ie7oh93hzg’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘nodeExecuteBefore’\n}”
2023-11-20T13:47:42.051Z | error | The session “ie7oh93hzg” is not registered. “{ sessionId: ‘ie7oh93hzg’, file: ‘abstract.push.js’, function: ‘send’ }”
2023-11-20T13:47:42.051Z | debug | Running node “Loop Over Items9” started “{\n node: ‘Loop Over Items9’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.debug’\n}”
2023-11-20T13:47:42.053Z | debug | Running node “Loop Over Items9” finished successfully “{\n node: ‘Loop Over Items9’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.debug’\n}”
2023-11-20T13:47:42.054Z | debug | Executing hook on node “Loop Over Items9” (hookFunctionsPush) “{\n executionId: ‘32171’,\n sessionId: ‘ie7oh93hzg’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘nodeExecuteAfter’\n}”
2023-11-20T13:47:42.054Z | error | The session “ie7oh93hzg” is not registered. “{ sessionId: ‘ie7oh93hzg’, file: ‘abstract.push.js’, function: ‘send’ }”
2023-11-20T13:47:42.054Z | debug | Save execution progress to database for execution ID 32171 “{\n executionId: ‘32171’,\n nodeName: ‘Loop Over Items9’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘nodeExecuteAfter’\n}”
2023-11-20T13:47:42.063Z | debug | Add editor-UI session “{ sessionId: ‘eh9hzcuwlw5’, file: ‘abstract.push.js’, function: ‘add’ }”
2023-11-20T13:47:42.066Z | debug | Proxying request to axios “{ file: ‘LoggerProxy.js’, function: ‘exports.debug’ }”
2023-11-20T13:47:42.074Z | debug | Running node “GET Raw Batch1” finished with error “{\n node: ‘GET Raw Batch1’,\n workflowId: ‘qkp1ObK2jApdiSDp’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.debug’\n}”
2023-11-20T13:47:42.075Z | debug | Executing hook on node “GET Raw Batch1” (hookFunctionsPush) “{\n executionId: ‘32173’,\n sessionId: ‘igj0nue36j’,\n workflowId: ‘qkp1ObK2jApdiSDp’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘nodeExecuteAfter’\n}”
2023-11-20T13:47:42.076Z | error | The session “igj0nue36j” is not registered. “{ sessionId: ‘igj0nue36j’, file: ‘abstract.push.js’, function: ‘send’ }”
2023-11-20T13:47:42.076Z | verbose | Workflow execution finished with error “{\n error: {\n context: {},\n severity: ‘warning’,\n name: ‘NodeApiError’,\n timestamp: 1700488062073,\n node: {\n parameters: [Object],\n id: ‘e9131ffa-96c5-44f9-b548-325bf75f335c’,\n name: ‘GET Raw Batch1’,\n type: ‘n8n-nodes-base.baserow’,\n typeVersion: 1,\n position: [Array],\n retryOnFail: true,\n maxTries: 5,\n executeOnce: false,\n alwaysOutputData: true,\n credentials: [Object],\n continueOnFail: true\n },\n httpCode: ‘ECONNREFUSED’,\n description: ‘connect ECONNREFUSED 127.0.0.1:8085’,\n message: ‘The service refused the connection - perhaps it is offline’,\n stack: ‘NodeApiError: The service refused the connection - perhaps it is offline\n’ +\n ’ at Object.getJwtToken (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Baserow/GenericFunctions.js:64:15)\n’ +\n ’ at processTicksAndRejections (node:internal/process/task_queues:95:5)\n’ +\n ’ at Object.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Baserow/Baserow.node.js:123:26)\n’ +\n ’ at Workflow.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Workflow.js:670:19)\n’ +\n ’ at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:652:53’\n },\n workflowId: ‘qkp1ObK2jApdiSDp’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.verbose’\n}”
2023-11-20T13:47:42.077Z | debug | Executing hook (hookFunctionsSave) “{\n executionId: ‘32173’,\n workflowId: ‘qkp1ObK2jApdiSDp’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘workflowExecuteAfter’\n}”
2023-11-20T13:48:20.927Z | debug | Executing hook (hookFunctionsPush) “{\n executionId: ‘32173’,\n sessionId: ‘igj0nue36j’,\n workflowId: ‘qkp1ObK2jApdiSDp’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘workflowExecuteAfter’\n}”
20T13:48:20.928Z | debug | Save execution progress to database for execution ID 32173 “{\n executionId: ‘32173’,\n workflowId: ‘qkp1ObK2jApdiSDp’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘workflowExecuteAfter’\n}”
2023-11-20T13:48:20.928Z | error | The session “igj0nue36j” is not registered. “{ sessionId: ‘igj0nue36j’, file: ‘abstract.push.js’, function: ‘send’ }”
2023-11-20T13:48:37.331Z | debug | Wait tracker querying database for waiting executions “{ file: ‘WaitTracker.js’, function: ‘getWaitingExecutions’ }”
2023-11-20T13:48:37.332Z | debug | Starting soft-deletion of executions (pruning cycle) “{ file: ‘pruning.service.js’, function: ‘softDeleteOnPruningCycle’ }”
2023-11-20T13:48:37.334Z [Rudder] debug: no existing flush timer, creating new one
2023-11-20T13:48:38.031Z | debug | Start processing node “Init File” “{\n node: ‘Init File’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.debug’\n}”
2023-11-20T13:48:38.032Z | debug | Executing hook on node “Init File” (hookFunctionsPush) “{\n executionId: ‘32171’,\n sessionId: ‘ie7oh93hzg’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘nodeExecuteBefore’\n}”
2023-11-20T13:48:38.032Z | error | The session “ie7oh93hzg” is not registered. “{ sessionId: ‘ie7oh93hzg’, file: ‘abstract.push.js’, function: ‘send’ }”
2023-11-20T13:48:38.033Z | debug | Running node “Init File” started “{\n node: ‘Init File’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.debug’\n}”
2023-11-20T13:48:38.050Z | debug | Running node “Init File” finished successfully “{\n node: ‘Init File’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.debug’\n}”
2023-11-20T13:48:38.051Z | debug | Executing hook on node “Init File” (hookFunctionsPush) “{\n executionId: ‘32171’,\n sessionId: ‘ie7oh93hzg’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘nodeExecuteAfter’\n}”
2023-11-20T13:48:38.051Z | error | The session “ie7oh93hzg” is not registered. “{ sessionId: ‘ie7oh93hzg’, file: ‘abstract.push.js’, function: ‘send’ }”
2023-11-20T13:48:38.052Z | debug | Save execution progress to database for execution ID 32171 “{\n executionId: ‘32171’,\n nodeName: ‘Init File’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘nodeExecuteAfter’\n}”
2023-11-20T13:48:38.065Z | debug | Found no executions to soft-delete (pruning cycle) “{ file: ‘pruning.service.js’, function: ‘softDeleteOnPruningCycle’ }”
2023-11-20T13:49:17.825Z [Rudder] debug: in flush
2023-11-20T13:49:17.825Z [Rudder] debug: cancelling existing timer…
2023-11-20T13:49:17.825Z [Rudder] debug: cancelling existing flushTimer…
2023-11-20T13:49:17.825Z [Rudder] debug: batch size is 2
Error fetching feature flags [CanceledError: canceled] { code: ‘ERR_CANCELED’ }
2023-11-20T13:49:34.306Z | verbose | User ced81ffc-6bf1-49d1-9cd9-d678a35de8e9 attempted to query non-shared workflow qkp1ObK2jApdiSDp “{ file: ‘executions.service.js’, function: ‘getExecutionsList’ }”
2023-11-20T13:49:35.013Z | debug | Start processing node “GET Raw Batch1” “{\n node: ‘GET Raw Batch1’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.debug’\n}”
2023-11-20T13:49:35.014Z | debug | Executing hook on node “GET Raw Batch1” (hookFunctionsPush) “{\n executionId: ‘32171’,\n sessionId: ‘ie7oh93hzg’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘nodeExecuteBefore’\n}”
2023-11-20T13:49:35.014Z | error | The session “ie7oh93hzg” is not registered. “{ sessionId: ‘ie7oh93hzg’, file: ‘abstract.push.js’, function: ‘send’ }”
2023-11-20T13:49:35.015Z | debug | Running node “GET Raw Batch1” started “{\n node: ‘GET Raw Batch1’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.debug’\n}”
2023-11-20T13:49:35.036Z | verbose | User attempted to access a workflow without permissions “{\n workflowId: ‘qkp1ObK2jApdiSDp’,\n userId: ‘ced81ffc-6bf1-49d1-9cd9-d678a35de8e9’,\n file: ‘workflows.controller.js’\n}”
2023-11-20T13:49:35.043Z | debug | Remove editor-UI session “{\n sessionId: ‘eh9hzcuwlw5’,\n file: ‘abstract.push.js’,\n function: ‘remove’\n}”
2023-11-20T13:49:35.062Z | debug | Proxying request to axios “{ file: ‘LoggerProxy.js’, function: ‘exports.debug’ }”
2023-11-20T13:49:35.448Z | debug | Proxying request to axios “{ file: ‘LoggerProxy.js’, function: ‘exports.debug’ }”
2023-11-20T13:49:35.629Z | debug | Proxying request to axios “{ file: ‘LoggerProxy.js’, function: ‘exports.debug’ }”
2023-11-20T13:49:36.020Z | debug | Running node “GET Raw Batch1” finished successfully “{\n node: ‘GET Raw Batch1’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.debug’\n}”
2023-11-20T13:49:36.022Z | debug | Executing hook on node “GET Raw Batch1” (hookFunctionsPush) “{\n executionId: ‘32171’,\n sessionId: ‘ie7oh93hzg’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘nodeExecuteAfter’\n}”
2023-11-20T13:49:36.022Z | error | The session “ie7oh93hzg” is not registered. “{ sessionId: ‘ie7oh93hzg’, file: ‘abstract.push.js’, function: ‘send’ }”
2023-11-20T13:49:36.023Z | debug | Save execution progress to database for execution ID 32171 “{\n executionId: ‘32171’,\n nodeName: ‘GET Raw Batch1’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘nodeExecuteAfter’\n}”
2023-11-20T13:49:36.102Z [Rudder] debug: no existing flush timer, creating new one
2023-11-20T13:50:18.531Z | debug | Wait tracker querying database for waiting executions “{ file: ‘WaitTracker.js’, function: ‘getWaitingExecutions’ }”
2023-11-20T13:50:18.532Z [Rudder] debug: in flush
2023-11-20T13:50:18.532Z [Rudder] debug: cancelling existing timer…
2023-11-20T13:50:18.532Z [Rudder] debug: cancelling existing flushTimer…
2023-11-20T13:50:18.532Z [Rudder] debug: batch size is 1
2023-11-20T13:50:33.215Z | debug | Start processing node “No Operation, do nothing” “{\n node: ‘No Operation, do nothing’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.debug’\n}”
2023-11-20T13:50:33.216Z | debug | Executing hook on node “No Operation, do nothing” (hookFunctionsPush) “{\n executionId: ‘32171’,\n sessionId: ‘ie7oh93hzg’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘nodeExecuteBefore’\n}”
2023-11-20T13:50:33.216Z | error | The session “ie7oh93hzg” is not registered. “{ sessionId: ‘ie7oh93hzg’, file: ‘abstract.push.js’, function: ‘send’ }”
2023-11-20T13:50:33.216Z | debug | Running node “No Operation, do nothing” started “{\n node: ‘No Operation, do nothing’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.debug’\n}”
2023-11-20T13:50:33.217Z | debug | Running node “No Operation, do nothing” finished successfully “{\n node: ‘No Operation, do nothing’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.debug’\n}”
2023-11-20T13:50:33.217Z | debug | Executing hook on node “No Operation, do nothing” (hookFunctionsPush) “{\n executionId: ‘32171’,\n sessionId: ‘ie7oh93hzg’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘nodeExecuteAfter’\n}”
2023-11-20T13:50:33.217Z | error | The session “ie7oh93hzg” is not registered. “{ sessionId: ‘ie7oh93hzg’, file: ‘abstract.push.js’, function: ‘send’ }”
2023-11-20T13:50:33.217Z | debug | Save execution progress to database for execution ID 32171 “{\n executionId: ‘32171’,\n nodeName: ‘No Operation, do nothing’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘nodeExecuteAfter’\n}”
2023-11-20T13:51:24.577Z | debug | Wait tracker querying database for waiting executions “{ file: ‘WaitTracker.js’, function: ‘getWaitingExecutions’ }”
2023-11-20T13:51:25.288Z | debug | Start processing node “GET DATA BATCH” “{\n node: ‘GET DATA BATCH’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.debug’\n}”
2023-11-20T13:51:25.289Z | debug | Executing hook on node “GET DATA BATCH” (hookFunctionsPush) “{\n executionId: ‘32171’,\n sessionId: ‘ie7oh93hzg’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘nodeExecuteBefore’\n}”
2023-11-20T13:51:25.289Z | error | The session “ie7oh93hzg” is not registered. “{ sessionId: ‘ie7oh93hzg’, file: ‘abstract.push.js’, function: ‘send’ }”
2023-11-20T13:51:25.289Z | debug | Running node “GET DATA BATCH” started “{\n node: ‘GET DATA BATCH’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.debug’\n}”
2023-11-20T13:51:25.291Z | error | The session “ie7oh93hzg” is not registered. “{ sessionId: ‘ie7oh93hzg’, file: ‘abstract.push.js’, function: ‘send’ }”
2023-11-20T13:51:25.292Z | debug | Proxying request to axios “{ file: ‘LoggerProxy.js’, function: ‘exports.debug’ }”
2023-11-20T13:51:26.047Z | debug | Running node “GET DATA BATCH” finished successfully “{\n node: ‘GET DATA BATCH’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.debug’\n}”
2023-11-20T13:51:26.049Z | debug | Executing hook on node “GET DATA BATCH” (hookFunctionsPush) “{\n executionId: ‘32171’,\n sessionId: ‘ie7oh93hzg’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘nodeExecuteAfter’\n}”
2023-11-20T13:51:26.049Z | error | The session “ie7oh93hzg” is not registered. “{ sessionId: ‘ie7oh93hzg’, file: ‘abstract.push.js’, function: ‘send’ }”
2023-11-20T13:51:26.050Z | debug | Save execution progress to database for execution ID 32171 “{\n executionId: ‘32171’,\n nodeName: ‘GET DATA BATCH’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘nodeExecuteAfter’\n}”
2023-11-20T13:52:06.623Z [Rudder] debug: in flush
2023-11-20T13:52:06.623Z [Rudder] debug: cancelling existing timer…
2023-11-20T13:52:06.623Z [Rudder] debug: queue is empty, nothing to flush
2023-11-20T13:52:24.150Z | debug | Start processing node “Get Rows BATCH” “{\n node: ‘Get Rows BATCH’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.debug’\n}”
2023-11-20T13:52:24.151Z | debug | Executing hook on node “Get Rows BATCH” (hookFunctionsPush) “{\n executionId: ‘32171’,\n sessionId: ‘ie7oh93hzg’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘nodeExecuteBefore’\n}”
2023-11-20T13:52:24.151Z | error | The session “ie7oh93hzg” is not registered. “{ sessionId: ‘ie7oh93hzg’, file: ‘abstract.push.js’, function: ‘send’ }”
2023-11-20T13:52:24.151Z | debug | Running node “Get Rows BATCH” started “{\n node: ‘Get Rows BATCH’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.debug’\n}”
2023-11-20T13:52:24.152Z | debug | Running node “Get Rows BATCH” finished successfully “{\n node: ‘Get Rows BATCH’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.debug’\n}”
2023-11-20T13:52:24.153Z | debug | Executing hook on node “Get Rows BATCH” (hookFunctionsPush) “{\n executionId: ‘32171’,\n sessionId: ‘ie7oh93hzg’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘nodeExecuteAfter’\n}”
2023-11-20T13:52:24.153Z | error | The session “ie7oh93hzg” is not registered. “{ sessionId: ‘ie7oh93hzg’, file: ‘abstract.push.js’, function: ‘send’ }”
2023-11-20T13:52:24.153Z | debug | Save execution progress to database for execution ID 32171 “{\n executionId: ‘32171’,\n nodeName: ‘Get Rows BATCH’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘nodeExecuteAfter’\n}”
2023-11-20T13:53:05.618Z | debug | Wait tracker querying database for waiting executions “{ file: ‘WaitTracker.js’, function: ‘getWaitingExecutions’ }”
2023-11-20T13:53:22.636Z | debug | Start processing node “Loop Over File” “{\n node: ‘Loop Over File’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.debug’\n}”
2023-11-20T13:53:22.637Z | debug | Executing hook on node “Loop Over File” (hookFunctionsPush) “{\n executionId: ‘32171’,\n sessionId: ‘ie7oh93hzg’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘nodeExecuteBefore’\n}”
2023-11-20T13:53:22.637Z | error | The session “ie7oh93hzg” is not registered. “{ sessionId: ‘ie7oh93hzg’, file: ‘abstract.push.js’, function: ‘send’ }”
2023-11-20T13:53:22.637Z | debug | Running node “Loop Over File” started “{\n node: ‘Loop Over File’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.debug’\n}”
2023-11-20T13:53:22.638Z | debug | Running node “Loop Over File” finished successfully “{\n node: ‘Loop Over File’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.debug’\n}”
2023-11-20T13:53:22.638Z | debug | Executing hook on node “Loop Over File” (hookFunctionsPush) “{\n executionId: ‘32171’,\n sessionId: ‘ie7oh93hzg’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘nodeExecuteAfter’\n}”
2023-11-20T13:53:22.639Z | error | The session “ie7oh93hzg” is not registered. “{ sessionId: ‘ie7oh93hzg’, file: ‘abstract.push.js’, function: ‘send’ }”
2023-11-20T13:53:22.639Z | debug | Save execution progress to database for execution ID 32171 “{\n executionId: ‘32171’,\n nodeName: ‘Loop Over File’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘nodeExecuteAfter’\n}”
2023-11-20T13:54:23.157Z | debug | Wait tracker querying database for waiting executions “{ file: ‘WaitTracker.js’, function: ‘getWaitingExecutions’ }”
2023-11-20T13:54:24.133Z | debug | Start processing node “GET DATA REPORTING” “{\n node: ‘GET DATA REPORTING’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.debug’\n}”
2023-11-20T13:54:24.134Z | debug | Executing hook on node “GET DATA REPORTING” (hookFunctionsPush) “{\n executionId: ‘32171’,\n sessionId: ‘ie7oh93hzg’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘nodeExecuteBefore’\n}”
2023-11-20T13:54:24.135Z | error | The session “ie7oh93hzg” is not registered. “{ sessionId: ‘ie7oh93hzg’, file: ‘abstract.push.js’, function: ‘send’ }”
2023-11-20T13:54:24.135Z | debug | Running node “GET DATA REPORTING” started “{\n node: ‘GET DATA REPORTING’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.debug’\n}”
2023-11-20T13:54:24.138Z | error | The session “ie7oh93hzg” is not registered. “{ sessionId: ‘ie7oh93hzg’, file: ‘abstract.push.js’, function: ‘send’ }”
2023-11-20T13:54:24.139Z | debug | Proxying request to axios “{ file: ‘LoggerProxy.js’, function: ‘exports.debug’ }”
2023-11-20T13:54:38.148Z | debug | Running node “GET DATA REPORTING” finished successfully “{\n node: ‘GET DATA REPORTING’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.debug’\n}”
2023-11-20T13:54:38.149Z | debug | Executing hook on node “GET DATA REPORTING” (hookFunctionsPush) “{\n executionId: ‘32171’,\n sessionId: ‘ie7oh93hzg’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘nodeExecuteAfter’\n}”
2023-11-20T13:54:38.149Z | error | The session “ie7oh93hzg” is not registered. “{ sessionId: ‘ie7oh93hzg’, file: ‘abstract.push.js’, function: ‘send’ }”
2023-11-20T13:54:38.149Z | debug | Save execution progress to database for execution ID 32171 “{\n executionId: ‘32171’,\n nodeName: ‘GET DATA REPORTING’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘nodeExecuteAfter’\n}”
2023-11-20T13:55:37.775Z | debug | Wait tracker querying database for waiting executions “{ file: ‘WaitTracker.js’, function: ‘getWaitingExecutions’ }”
2023-11-20T13:55:38.491Z | debug | Start processing node “Get DATA REPORTING” “{\n node: ‘Get DATA REPORTING’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.debug’\n}”
2023-11-20T13:55:38.491Z | debug | Executing hook on node “Get DATA REPORTING” (hookFunctionsPush) “{\n executionId: ‘32171’,\n sessionId: ‘ie7oh93hzg’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘nodeExecuteBefore’\n}”
2023-11-20T13:55:38.492Z | error | The session “ie7oh93hzg” is not registered. “{ sessionId: ‘ie7oh93hzg’, file: ‘abstract.push.js’, function: ‘send’ }”
2023-11-20T13:55:38.492Z | debug | Running node “Get DATA REPORTING” started “{\n node: ‘Get DATA REPORTING’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.debug’\n}”
2023-11-20T13:55:38.493Z | debug | Running node “Get DATA REPORTING” finished successfully “{\n node: ‘Get DATA REPORTING’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.debug’\n}”
2023-11-20T13:55:38.493Z | debug | Executing hook on node “Get DATA REPORTING” (hookFunctionsPush) “{\n executionId: ‘32171’,\n sessionId: ‘ie7oh93hzg’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘nodeExecuteAfter’\n}”
2023-11-20T13:55:38.494Z | error | The session “ie7oh93hzg” is not registered. “{ sessionId: ‘ie7oh93hzg’, file: ‘abstract.push.js’, function: ‘send’ }”
2023-11-20T13:55:38.494Z | debug | Save execution progress to database for execution ID 32171 “{\n executionId: ‘32171’,\n nodeName: ‘Get DATA REPORTING’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘nodeExecuteAfter’\n}”
2023-11-20T13:56:20.260Z | debug | Add editor-UI session “{ sessionId: ‘38r70hso7xw’, file: ‘abstract.push.js’, function: ‘add’ }”
2023-11-20T13:56:20.305Z | debug | Remove editor-UI session “{\n sessionId: ‘38r70hso7xw’,\n file: ‘abstract.push.js’,\n function: ‘remove’\n}”
2023-11-20T13:56:36.221Z | debug | Start processing node “Set Fields Reporting” “{\n node: ‘Set Fields Reporting’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.debug’\n}”
2023-11-20T13:56:36.222Z | debug | Executing hook on node “Set Fields Reporting” (hookFunctionsPush) “{\n executionId: ‘32171’,\n sessionId: ‘ie7oh93hzg’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘nodeExecuteBefore’\n}”
2023-11-20T13:56:36.222Z | error | The session “ie7oh93hzg” is not registered. “{ sessionId: ‘ie7oh93hzg’, file: ‘abstract.push.js’, function: ‘send’ }”
2023-11-20T13:56:36.222Z | debug | Running node “Set Fields Reporting” started “{\n node: ‘Set Fields Reporting’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.debug’\n}”
2023-11-20T13:56:36.240Z | debug | Running node “Set Fields Reporting” finished successfully “{\n node: ‘Set Fields Reporting’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘LoggerProxy.js’,\n function: ‘exports.debug’\n}”
2023-11-20T13:56:36.241Z | debug | Executing hook on node “Set Fields Reporting” (hookFunctionsPush) “{\n executionId: ‘32171’,\n sessionId: ‘ie7oh93hzg’,\n workflowId: ‘2RuMSv4YkXEzPaKl’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘nodeExecuteAfter’\n}”
2023-11-20T13:56:36.241Z | error | The session “ie7oh93hzg” is not registered. “{ sessionId: ‘ie7oh93hzg’, file: ‘abstract.push.js’, function: ‘send’ }”
2023-11-20T13:56:36.241Z | debug | Save execution progress to database for execution ID 32171 “{\n executionId: ‘32171’,\n nodeName: ‘Set Fields Reporting’,\n file: ‘WorkflowExecuteAdditionalData.js’,\n function: ‘nodeExecuteAfter’\n}”
2023-11-20T13:56:36.244Z [Rudder] debug: no existing flush timer, creating new one
The extra host should do the job and it should save on some of the network routing as long as baserow is available and listening on that IP.
I think as you have tested with Baserow cloud and seen that it can be quick that is enough to possibly show that the issue is not directly related to n8n or baserow itself and it is something between. Hopefully the change to keeping the traffic internal will sort it other wise you may need to dig into the server and other docker settings in more detail.
