N8n Keeps Going Offline Despite Stable Internet
Hi everyone,
Looking for some help here.
A few details:
· My internet is fast and stable
· The n8n cloud status site says everything is operational
· No VPN or game booster running
· I’m on the cloud-hosted version
· This might have been happening for a while, but I only noticed it today because I actually need to get work done on n8n
Would really appreciate any advice. Thanks in advance
@aleklang I doubt it’s your instance going down, check your firewall settings, extension settings and your browser console, what errors are you getting?
Hi @aleklang
If the drops are short and clear up on their own, this is upgrade restarts. A Cloud workspace on Update cadence “Every new release” with Maintenance window “Upgrade anytime” takes each release the moment it ships, on average one a day, and every upgrade is a 1 to 2 minute restart where the editor goes down. A scheduled upgrade is not an incident, so the status page stays green through it. Open the Cloud dashboard, Manage > Workspace > Updates & maintenance, set Maintenance window to “Pick a window” outside your working hours and Update cadence to “Security & stability”.
