NEED YOUR HELP : n8n AI Agent Node + Postgres Chat Memory (Supabase)
Hey everyone, I’m running into an issue connecting my AI Agent’s Postgres Chat Memory node to a Supabase instance.
What is the error message : couldn’t connect with these settings, connect ENETUNREACH 2406:da14:271:9921:e596- local (:::0)
  • n8n version: latest one
  • Database (default: SQLite): supabase (postgres)
  • Running n8n via (Docker, npm, n8n cloud, desktop app):cloud
  • Operating system: windows
@Rudra_Bhattacharjee that error is IPv6 — n8n cloud can’t reach the IPv6 address supabase gave you. go to supabase dashboard → project settings → database, copy the connection string under “URI” with the IPv4 toggle ON, use that in your postgres credentials instead. here’s a minimal agent + postgres memory setup:
plug your supabase postgres creds (with the IPv4 URI) into the memory node, add your openai key to the model node, should connect right away.
I have seen this a couple times with n8n + Supabase setups that ENETUNREACH error usually isn’t about the credentials or node config itself.
It’s more of a network/connectivity issue, especially when IPv6 gets involved with cloud instances.
Most people try to fix it from the database side, but the issue is often happening earlier in the connection layer.
Quick question are you connecting using the default Supabase connection string or a modified one?
