By that error, it looks like your content is too long for the Notion API - can you try splitting up your text and seeing if that fixes up the error? You’re almost double the limit of what their API expects
but I now found another strange issue.
I set the time condition to on or before the tima stemp, but it work with 1day or 10min earlier diffent.
I’ve check the time zone setting, but still can’t figure out why.
Hi @ykh525050 That’s helpful enough as it lets me know what version you’re on, and that you’re self hosting But for future reference, you’d know what database you’re using as well as your EXECUTIONS_PROCESS setting in your docker-compose.yml file. AWS allows for several server types, so I’m not sure what you’re running there.
The timezone and time on your AWS server and on your n8n instance may not match - that could be the culprit here.
