OpenAI whisper Model
Hi guys, I’m trying to set up my openAI voice transcription but it’s not working with telegram voicenotes. I have tried setting up some code in the function node to convert the .oga file from telegram to .ogg or .mp3 but the file extension is still stuck at .oga and it seems openAI does not recognize this extension. Anybody else going through this issue? How did you fix it?
Hope all is well, welcome to the community.
If I understood your question correctly, it should be pretty straightforward to feed oga to the transcription model:
The flow is:
get the message → download the file → transcribe the file.
this is what I mean.
You response was hidden by the platform for some reason. Try posting again.
getting the file is not an issue as I have done that successfully. I keep getting this error message every time I want to execute the step with the transcribe node.
Ok, this error has nothing to do with the initial message, and it is not even mentioned there. You may need to go to your openai account and check/add balance.
okay, I will do that then get back to you. Thank you very much and thanks for welcoming me into the community.
You are very welcome, let’s see if that helps.
