Outlook send message node HTML body
Hi there,
I am currently trying to build a workflow that sends a summary of last weeks Notion database updates via Outlook. I aggregated the notion updates and converted them to a HTML table. However, if I use this html table input for the email body it will send the HTML code as text (“
Is there an “is html” checkbox that I am missing? I looked everywhere.
Thank you!
Best
Michael
Hi @MD88 :wave: There should be this option at the bottom of the node under additional fields:
Do you have this enabled? :slight_smile:
Thank you, @EmeraldHerald! I must have overlooked this field! Works like a charm now :slight_smile:
