Passthru input values in nodes?
Is there a way to “enable” passthru of the input values?
I need values from the top of the flow and need to be merging them all the time… I’m I missing something?
A lovely toogle button to passthru the input msg would be wonderful!
Welcome to the community @Ricardo_Caldeira !
Tip for sharing information
Pasting your n8n workflow
<your workflow>
You do not have to merge the nodes all the time but sometimes it is the best approach to follow (depends on your use case). You can reference the input values of any previously executed nodes as per NodeOutputData | n8n Docs.
