I am trying to integrate the firebase-admin module into my n8n workflow to connect to Firebase from a self-hosted n8n instance running on Docker. I have successfully installed firebase-admin in the Docker container, but when I try to use it in a Code node, I get an error saying that the module cannot be found. Despite the module showing as installed when I inspect the container, it fails when I try to require it inside n8n.
The error message I receive is:
VMError: Cannot find module 'firebase-admin'
"errorMessage": "Cannot find module 'firebase-admin' [line 2, for item 0]",
"errorDescription": "VMError",
"errorDetails": {},
"n8nDetails": {
"nodeName": "Check Center firebase",
"nodeType": "n8n-nodes-base.code",
"nodeVersion": 2,
"itemIndex": 0,
"n8nVersion": "1.63.4 (Self Hosted)",
"binaryDataMode": "default",
"stackTrace": [
"VMError: Cannot find module 'firebase-admin'",
" at Resolver.resolveFull (/usr/local/lib/node_modules/n8n/node_modules/@n8n/vm2/lib/resolver.js:126:9)",
" at Resolver.resolve (/usr/local/lib/node_modules/n8n/node_modules/@n8n/vm2/lib/resolver.js:121:15)",
" at resolve (/usr/local/lib/node_modules/n8n/node_modules/@n8n/vm2/lib/nodevm.js:317:21)",
" at VM2 Wrapper.apply (/usr/local/lib/node_modules/n8n/node_modules/@n8n/vm2/lib/bridge.js:490:11)",
" at requireImpl (/usr/local/lib/node_modules/n8n/node_modules/@n8n/vm2/lib/setup-node-sandbox.js:90:19)",
" at require (/usr/local/lib/node_modules/n8n/node_modules/@n8n/vm2/lib/setup-node-sandbox.js:171:10)",
" at /usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Code:2:15",
" at /usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Code:77:2",
" at NodeVM.run (/usr/local/lib/node_modules/n8n/node_modules/@n8n/vm2/lib/nodevm.js:497:23)"
- n8n version: 1.63.4 (Self Hosted)
- Database (default: SQLite): SQLite
- n8n EXECUTIONS_PROCESS setting (default: own, main): own
- Operating system: Ubuntu 24.04 LTS
