Same problem here. Things is this problem happen occasionally, and when I click save the workflow with a Telegram trigger turn on, the error message appear and prevent me to save or sometimes (when the workflow is inactive) prevent me to active the workflow. But if i just do nothing and wait for 10 minutes then i can save and active workflow like normal.
After a bit of research I think this problem related to your domain SSL certificate. But I don’t know the solution for it.
I’m self hosting my n8n too with a domain i bought (very cheap) and looking hard to a way to solve this too. Very annoying.
I also faced this problem and overcame it thanks to the hint from your webhook URL. You can find Webhook URLs in our Telegram Trigger node. In my case, it returns a JSON containing the hint as follows.
"hint": "Click the 'Execute workflow' button on the canvas, then try again. (In test mode, the webhook only works for one call after you click this button)"
When it fails to run in the testing environment, first activate the workflow, execute it once in the production environment, and then switch back to testing mode to run it normally
I ran into this exact issue while hosting n8n on a VPS with a DuckDNS domain and Nginx + Certbot. The error was caused by a DNS resolution problem — the server couldn’t resolve my DuckDNS hostname properly.
Here’s what worked for me:
Checked the DNS setup on my VPS with
cat /etc/resolv.conf
Updated it to use reliable DNS servers (Cloudflare + Google):
