Problems with open ai api
Has anyone presented the problem that every time you try to buy tokens for open ai API it rejects your card, even though you have made every single thing their help support has recommended, and if so have you been able to solve it, and how? If someone from Mexico can answer this question it would be ideal since i am from there, and maybe knows more about banks and all that other stuff
Hey @Daniel_Rivero
Yes, many users in Mexico have reported issues when trying to buy OpenAI API tokens ,specifically that their cards get rejected even after following all OpenAI support recommendations.
This usually happens due to how Mexican banks handle international transactions, especially with online U.S.-based services like OpenAI.
Have you tried any international cards?
Try “Wise” USD Card
Thanks for your reccomendation, however I´ve tried and appearantly I can´t use the wise card from mexico, do you know any other way this can be solved, anyway thanks for your help
Hey @Daniel_Rivero ,
You can try
Gotyme
Paypall
