An option to publish a custom node from UI directly into npm would be helpful. Currently coding a npm package again defeats the purpose of no code workflows.
General API calls and massaging of data
n8n version:
Database (default: SQLite): SQLite
n8n EXECUTIONS_PROCESS setting (default: own, main): own
Running n8n via (Docker, npm, n8n cloud, desktop app): npm
This is a great idea. Thank you for the feedback!
I would suggest to move this post to the feature-requests category, if you’re ok with it? There you and other users who relate can also vote on the request.
n8n looks at the most voted ideas when planning new feature developments and it also helps us understand what means the most for our users
