Quiz 1 results were not updated
Hello! I contacted you via email because my course 1 quiz result was not updated (I failed the 1st time and retook it, but the results shown are still the ones of my first attempt). AI kinda hepled but still said I needed review from a human, but I haven’t recieved an answer yet
I would retake it again and see if it updates your score then. Maybe it was down for a bit when u took ur test. Ensure you also contacted the team thru the workflow as in the tutorial.
To get the badge you need 2
Past the test both sections with (i believe an 80 or 90)
Contact the team by following the workflow.
