Running n8n on docker , code error 159
Hello,
I have some trouble using n8n with docker on my rasberry pi 4 : i have an errorr code 159 when running the container.
Here is some information on my configuration
docker-compose.yml :
services:
n8n:
image: n8nio/n8n:latest
platform: linux/arm64
container_name: n8n
restart: unless-stopped
ports:
  - "5678:5678"
env_file:
  - .env
volumes:
  - ./n8n_data:/home/node/.n8n
.env :
N8N_BASIC_AUTH_ACTIVE=true
N8N_BASIC_AUTH_USER=myusername
N8N_BASIC_AUTH_PASSWORD=mypassword
N8N_HOST=192.168.1.23 #ip de mon raspberry
N8N_PORT=5678
N8N_SECURE_COOKIE=false
Docker version :
Docker version 28.5.1, build e180ab8
Docker compose version :
Docker Compose version v2.40.2
Os architecture :
aarch64
Raspberry info :
PRETTY_NAME=“Raspbian GNU/Linux 12 (bookworm)”
NAME=“Raspbian GNU/Linux”
VERSION_ID=“12”
VERSION=“12 (bookworm)”
VERSION_CODENAME=bookworm
ID=raspbian
ID_LIKE=debian
Results when running command “docker compose up -d” & docker ps" :
loris@raspberrypi:~/projet/n8n $ docker compose up -d
[+] Running 2/2
:check_mark: Network n8n_default Created 0.2s :check_mark: Container n8n Started 0.8s loris@raspberrypi:~/projet/n8n $ docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
400a21684fbb n8nio/n8n:latest “tini – /docker-ent…” 6 seconds ago Restarting (159) Less than a second ago
Thank you for your help.
