Shopify Triggers - How to make them work?
Hello there im trying to get the Shopify Trigger to work but im getting an error if i try to Listen for events
Problem running workflow
Your request is invalid or could not be processed by the service
Show Details
Shopify Trigger: 422 - {"errors":{"address":["is not allowed"]}}
If I Listen - For events
What am I missing here ?
Thanks in advance
Hi @Chipset, are you by any chance running n8n locally? How do the webhook URLs shown on your Shopify trigger node look like?
Shopify rejects non-HTTPS URLs for example, so this could be a possible cause for the Shopify error you are seeing.
I have the same problem as the OP, and I am using n8n locally. Webhook URL for me is:
http://localhost:5678/webhook-test/33712f58-c458-4d70-a74d-41953be96d81/webhook
So at least in my case, it looks like I need to solve for the HTTPS issue. Thanks for the pointer.
Welcome to the community @pdxrlk :tada:
Glad this helps already! As for obtaining a public HTTPS URL, the simplest way would be the use of the n8n-provided tunnel for a quick local test:
If you are running n8n on a web server, you want to make sure it’s available under a more permanent hostname and configure the webhook URL:
My URL was local,
Solution :
Cloudflared tunnel to have access to service as https
and enviromental variable “webhook URL” for the Docker container as you said.
Sweet, glad to hear that was it. Thanks a lot for confirming :slight_smile:
