Hi everyone, I’m having an issue with the Split In Batches node. It processes the first batch correctly, but then it doesn’t continue to the next batch.
My workflow is
HTTP Request → Split In Batches → Function → Database
Batch size is set to 10, and I have around 100 items, but only the first 10 get processed.
I connected it like this:
• Main output → Function → Database
• But I’m not sure if I connected the loop correctly
return $input.all().map(item => ({
json: {
After the first batch runs, the workflow just stops instead of continuing with the remaining items.
Do I need to connect the “Continue” output back into the Split In Batches node?
- n8n version:
- Database (default: SQLite):
- Operating system:
