I am trying to take an array (with multiple fields) returned by API and use the split out (node) for the ID field to use the loop over items to update individual records via API. No matter what I do I get a split out error when feeding the array to it. I also tried pulling out the ID to create a string and a separate array and it still does not output the result.
What is the error message (if any) ?this.getNodeParameter(…).split is not a function
**n8n version:1.81.4
