Split out not working for string array
i am trying to split out a string array, but n8n says “[ERROR: Can’t determine which item to use]”
  • n8n version: 1.68.0
  • Operating system: Linux
Welcome to the community @j-dimension !
Tip for sharing information
Pasting your n8n workflow
<your workflow>
The “Fields to Split Out” is expected to be the field name that you want to split. By using an expression you are actually giving the value of that field. Hence n8n tells you that the key (field) with such a name does not exist.
You are absolutely right. Thank you so much for the quick reply!
Regards
Jens
