Title: Pinecone Vector Store connection issue with Starter (Serverless) plan in n8n Post: Hi everyone 👋 I’m trying to connect Pinecone with n8n using the Pinecone Vector Store node, but I’m facing this error: “Couldn’t connect with these settings Aut
:thinking: My confusion:
n8n Pinecone Vector Store node seems to expect the older Pod-based / environment-based setup, but my Pinecone index is Serverless (Starter plan).
:red_question_mark: My question:
What is the correct way to connect Pinecone Serverless (Starter plan) with n8n?
  • Is there a specific configuration I’m missing?
  • Or is the Pinecone Vector Store node not compatible with serverless indexes yet?
  • Do I need to use HTTP Request node instead?
now my version is 2.19.2 still connection issue
still not working
Hi - Developer advocate from Pinecone here. The Pinecone Vector Store node does support serverless indexes. Here are two sample workflows you can start from:
If you’d like to paste your workflow json in here, that would also be helpful in diagnosing issues. Based on the error in the title, I’d also suggest double-checking your credential setup - whether through QuickConnect (which will create an API key in your account for you) or manually via API key.
