Tunnel problem
Hi,
I run the following command on my new machine, win11 OS, private. I try the following command to create tunnel and do a telegram bot, but the tunnel isn’t created and I’m failing constantly.
Please help :folded_hands:
running the folowing command using cmd -
docker run -it --rm --name n8n -p 5678:5678 -e GENERIC_TIMEZONE=“Asia/Jerusalem” -e TZ=“Asia/Jerusalem” -e N8N_ENFORCE_SETTINGS_FILE_PERMISSIONS=true -e N8N_RUNNERS_ENABLED=true -v n8n_data:/home/node/.n8n docker.n8n.io/n8nio/n8n start --tunnel
error received in cmd -
Initializing n8n process
n8n ready on ::, port 5678
n8n Task Broker ready on 127.0.0.1, port 5679
Failed to start Python task runner in internal mode. because Python 3 is missing from this system. Launching a Python runner in internal mode is intended only for debugging and is not recommended for production. Users are encouraged to deploy in external mode. See: Task runners | n8n Docs
[license SDK] Skipping renewal on init: license cert is not initialized
Registered runner “JS Task Runner” (p0HzYgUySJcX_XIvVFt56)
Version: 2.0.3
Start Active Workflows:
Thanks for the link.
I’ts not clear what can solve the problem.
Should I try everything on it?
Please try to give me more info, and much more simple, using simple steps.
Thanks🙏
--tunnel option was removed in v2.
Thanks.
So I understand there is no simple command to run in cmd?
I tryed ngrok - the solution also not clear to me. No simple steps to use it :unamused_face:
In case you have more simple solution or simple steps please share.
Thanks :folded_hands::heart:
It is actually simple. Using ngrok the command is ngrok http 5678. You can also setup Easypanel or Dokploy if you have a VPS, those are low-code Docker container maintenance services. And there is a huge amount of resources on the internet about ngrok.
Thanks.
I’ll try your solution.:folded_hands::heart:
--tunnel was removed. Stop asking ChatGPT and pasting its answer here.
Well you forgot to exclude your bot from Jobs channel. Rest assured the n8n team will handle this for you.
