I guess its not essential but it sure would be nice to have an option to remove certain fields or items from the data using the set node? i guess a function (code) node could do the job just fine.
Hey @Josh-Ghazi,
Are you thinking maybe disable all the input items and just have a button to remove what you don’t want instead of having to add in the items you do want to keep?
sorry my brain isnt working right now
Yup, a “remove columns” setting would be great, plenty of times you want to keep the same object except a couple of entities.
I think the set node’s vision is to let you prepare an object to be ingested by future oper
Things like intuitive drag and drop for entire key-value pairs, key deletion (column drop) mode, suggested expressions given variable name, and nested objects can all make the experience a lot more fluid. Even certain list operations could make building out an output JSON amazingly simple since some applications require very specific data shapes to work.
Trying to prep the shape of the object as much as possible to be ingested by future operations.
Hi,
I’m wondering if anyone has any other suggestions on how to improve the Set Node or any specific pain that would like to share.
We’re currently working on an update, so now it’s the right time to share your ideas ![]()
Thanks!
Maybe good to post a new announcement on it. ![]()
Not everyone checks out old topics that are being revived I guess.
My biggest pain point with the set node is its “confusing” layout when more than a few fields get set.
From my point of view, a more table like layout would be more intuitive to use and better readable:
| Name | Value |
| first_name | Max |
| rnd_num | {{Math.floor(Math.random()*999999999)}} |
| city | Vienna |
| phone | 0043670123456 |
Maybe the layout changes between a table layout and the current layout, depending on the width of the config window.
Thank you for the feedback ![]()
@giulioandreini got some more ideas today when I worked with the Set node:
Some sort of JSON editor, like the expression editor, just optimized for JSON.
I had the “problem” of setting fields multiple layers deep. (which is possible right now with the “dot notation”)
Setting bigger arrays would be more efficient and the overview would also be better if you know the JSON syntax.
A Button to add more fields which won’t close would be cool.
Now I have to spam my mouse to get as many fields as possible without having to open the drop down for selecting the field type again.
Thanks again @FelixL !
I don’t know if this is still on the horizon, but I would like to see something like this:
http://community.n8n.io/t/does-a-json-builder-node-exists/27228
Also the possibility to rearrange fields via drag and drop and to be able to mix different field types (number, string, boolean, etc) to output the JSON in our own personalized order.
