Airtable Node Typecast not working Issue. Is it still a bug?
Hello. I am trying to map the link to another record field by enabling the Typecast option, but it does not work, and I found some threads discussing this issue from years ago.
Below thread shows the exact issue I am facing.
Any chance to confirm it is a bug and can be fixed soon?
*UPDATE: Auctallyt the Typecast option is working. It is just there’s no option to make the readonly field to be editable, we have to manually modify the Airtable node JSON as “readOnly”: to false.
Thanks
You need to update your n8n, this bug of the field being readonly was fixed months ago in an update.
Good to know! But I just updated it last month… um, will do an update later Thanks
By the way, would you mind if I ask this: after the update, do I need to rebuild the flow by replacing the latest Airtable node since I have manually modified that node for this case (readOnly set to false)?
Thanks
