How to view running workflow logs
  • **n8n version:**1.117.3
  • Database (default: SQLite):SQLite
  • n8n EXECUTIONS_PROCESS setting (default: own, main):own
  • Running n8n via (Docker, npm, n8n cloud, desktop app):Docker
  • Operating system: windows
Hi @lironghai ,
All logs can be found under the “Execution” tab:
To see logs in the real time, in the “Editor” tab, on the bottom of the screen is a tab “Logs”. Click it to expand or use a pop out to open a separate panel:
Hope this helped :waving_hand:
Gosia
In the “Execution” tab, only completed logs can be viewed. Logs in progress cannot be displayed, and it keeps spinning, waiting for execution to complete
