Issues with license key (self-hosted)
Hi!
I am using self-hosted n8n Community Edition (version 1.122.5).
I requested a free Community Edition license key from the “Usage and plan” page.
The request seems to be accepted: I see the “Your license key is being generated” notification and in the browser Network tab the community-registered request returns HTTP 200 with the following
JSON:{
“data”: {
“title”: “Your license key is being generated!”,
“text”: “We’ve got your request, and it’s currently being processed. Your license will be generated soon and sent to m***ov@gmail.com.”
Another request returns {"status":"Ok"}.
However, I do not receive any email with the license key on this address (also checked Spam/Promotions folders
Could you please check on your side whether the license email is actually being sent and/or manually send me the license key for this email address?
An n8n employee said that it will be fixed soon. You can find the post here: I did not receive my free self‑hosted activation key - #2 by jabbson
we will have to be patient and wait the fix :melting_face:
Thank you! Hope, it’ll be patched soon.
Hey guys did any of you received the license key mail ??
Hi everyone,
I’m having a similar issue but with a twist. I actually did receive the license key via email.
The problem is: when I enter the license key, the system says it’s OK/accepted, but it doesn’t actually activate. Nothing changes, the features remain locked.
I also ran the connectivity test as suggested:
  • curl https://api.n8n.io → Works fine, server responds
  • curl https://license.n8n.io → Returns {"code":404,"message":"not found"}
So it seems like the license server endpoint is returning a 404, which might explain why the activation isn’t completing even though the key is accepted.
Is anyone else experiencing this? Is the license server currently down?
Environment:
  • n8n version: 1.122.5
  • Self-hosted on Ubuntu 20.04
