Need help with n8n workflows (paid)
Seeking experienced n8n (or similar automation tools) specialist to design and scale finance workflows in a fintech environment. This focuses on developing dependable, structured processes, not just simple automations, by integrating tools like Airtable, Google Sheets, and Slack, leveraging APIs and webhooks, and enhancing existing flows. It’s a plus to have experience with financial data or comparable systems.
If this sounds like the right fit for you, feel free to reach out.
Hi HRLead, this is my exact wheelhouse. I have built systems that integrated these tools with fault tolerant architecture that can be scaled as needed.
Here si my portfolio: Gabriel | AI & Automation Architect
You can reach me via email: ola.gabriel19@gmail.com
Telegram: @whiskey345
Happy to help build your workflow.
Hey :waving_hand:,
I’m Milan, with 8 years of experience in Business Automation and AI. Including 2 years at Apify working on enterprise-level browser automation.
Currently specializing in n8n, but also proficient in Python & Javascript.
Find out more about my work here:
If you think I might be a match, please:
Book a call here with me
Or reach out at hello@smoothwork.ai
Looking forward to hearing from you!
I also have a bachelor degree in Finance, and worked on automation projects in the industry!
And I also regularly work with all of: Airtable, Slack, Sheets
If you need I am available here:
I am one of top 50 verified template creators:
I am also capable of building custom community n8n node too:
  1. https://www.npmjs.com/package/n8n-nodes-pdfbro
  2. https://www.npmjs.com/package/n8n-nodes-ocrbro
  3. https://www.npmjs.com/package/n8n-nodes-ttsbro
Apart from that I’m also a full-stack developer with the right Gen AI experience, which makes me a solid plus for your team[but right now only vibecoding]
Check my recent gen ai projects… I built a native Android automation agent too. It’s worth a look:
I can build complex AI automations directly in code, not just inside n8n
I recently started posting my n8n work on YouTube with explanations:
You can schedule a quick call with me: N8N Project Consultation with Vaar | Iamvaar | Cal.com
Fun fact… I even made an n8n workflow to find a few n8n project leads for myself so I truly believe in what I do…
I started asking My recent clients for honest feedbacks so here is one testimonial: https://www.youtube.com/watch?v=TqBy3SVCHgQ&list=PLAJltY5bp6yiZ3sFBjm7bfrkLXSGtJX8m
Here is my linktree: iamvaar | X | Linktree
And I also built low latency voice appointment scheduler with live ai avatar[in code]:
I built AI search visibility tracker[I am capable of building complex web scraping automations in python too]:
And done many other big projects too which are under NDA’s so technically I can’t reveal them.
Hey @HRLead ,
This aligns well with the kind of systems I build—focused on structured, reliable workflows, not just quick automations.
I’ve worked on n8n-based systems involving:
  • Multi-step pipelines (Airtable ↔ Google Sheets ↔ APIs)
  • Slack alerts + approval workflows
  • Error handling (retries, logging, fallback paths)
A couple of relevant projects:
  • Customer Onboarding Automation (HubSpot + Slack + Gmail)
    → Structured workflow with validation, notifications, and fail-safes
  • Lead Processing Pipeline (Google Maps → Sheets → Outreach)
    → Multi-step data handling with cleanup and API integrations
  • AI Appointment System (Calendar + WhatsApp + APIs)
    → Real-time workflows with webhook handling and data syncing
Full portfolio (with demos):
https://muhammad-ai-automations.notion.site/Muhammad-Bin-Zohaib-AI-Automation-Projects-29da292a241380f889c2e337a134c010
Happy to review your current workflows and suggest improvements.
You can reach me here or at:
muhammad.specials@gmail.com
Hi @HRLead
My name is Ion Turcanu, from Italy.
I think i could be the right guy you. Currently working for a swiss company that uses the same identical technical stack you mentioned. I don’t know where you’re from but everybody know how much the swiss market pay attention to details and reliability.
I don’t simply create some n8n automations, i create high ROI systems that really bring value to companies.
I could show some of my work that i did for very big companies in Switzerland.
Feel free to message me or reach me out at ion@automatiko.ai
Hi
​In a fintech environment, I know that a dropped webhook, a duplicated entry, or a misfired automation isn’t just an annoyance—it’s a financial and compliance risk. You aren’t looking for someone to just connect App A to App B; you need a systems architect who builds resilient, scalable, and auditable workflows.
​I specialize in designing highly dependable automation architectures using n8n, specifically tailored for financial data and complex operational flows.
​Why My Approach Fits Your Needs
​*“Developing dependable, structured processes, not just simple automations.”*
​This line in your description stands out to me. My automation philosophy is built on error-handling, idempotency, and data validation. When I build a workflow, I assume APIs will timeout and rate limits will be hit, so I build the necessary retries and fail-safes directly into the n8n nodes.
Here is how my expertise aligns with your stack:
  • n8n & Custom Integrations: Deep experience leveraging the full power of n8n, including complex routing, writing custom HTTP requests, and handling incoming/outgoing Webhooks securely.
  • The Core Stack (Airtable, Sheets, Slack): I regularly use Airtable as a robust relational database for operational workflows, Google Sheets for dynamic reporting, and Slack for human-in-the-loop approvals and critical alerting.
  • Fintech & Financial Data: I understand the strict requirements of handling financial data. I know how to structure workflows to ensure atomic transactions (meaning a process either fully completes or safely rolls back/alerts), ensuring your ledgers and operational data remain perfectly synced.
  • Enhancing Existing Flows: I don’t just build from scratch; I can audit your current automations to identify bottlenecks, reduce redundant API calls, and fortify them against edge-case failures.
​Proposed Next Steps
​If we work together, my first step would be a Workflow Audit. I will review your current critical paths, identify immediate vulnerabilities or inefficiencies, and map out a scalable architecture for your upcoming finance processes.
​I would love to get a better understanding of the specific financial data pipelines you are trying to scale right now.
​Are you available for a brief, 15-minute technical scoping call later this week to discuss your current infrastructure?
​Best regards,
Agbaje Olarewaju
Hi! I’m reaching out regarding the n8n specialist role.
I saw your post and I’m very interested because I don’t just build “simple automations”—I focus on creating solid, structured workflows that are dependable and easy to scale.
I have experience with:
  • Designing complex n8n flows using APIs and Webhooks.
  • Integrating Airtable, Google Sheets, and Slack into reliable systems.
  • Managing data structures that stay clean as they grow.
I understand that in fintech, every data point matters. You can see some of my work and more about my background here: https://mikedevai.netlify.app/
I’d love to discuss how I can help improve and scale your current financial processes. Looking forward to hearing from you!
I build finance and operations automation workflows in n8n regularly – API integrations with Airtable, Google Sheets, and Slack are part of nearly every system I deliver.
A recent project involved connecting multiple data sources through webhook-driven n8n pipelines with structured data transformation, conditional routing, and automated Slack notifications – similar pattern to what fintech workflows typically require. I handle the full lifecycle: webhook/API ingestion, data validation, cross-platform sync, and error handling with retry logic so nothing fails silently.
Founder of Evara AI (incubated at IIT Bhubaneswar), 1.5+ years building production automation systems. I can carve out time for an ongoing engagement if the scope is right. DM me or reach out at priyanshukumarmaurya2224@gmail.com to discuss specifics.
Hi there,
I’ve been working with n8n and low-code architecture for a while, and your focus on “dependable, structured processes” resonates with me. In fintech, a failed webhook shouldn’t mean lost data.
Why I’m a good fit for this:
  • n8n Expert: I build self-hosted, scalable workflows (Docker/PostgreSQL) with complex error-handling and data transformation (JavaScript/Python nodes).
  • Fintech Experience: I’ve integrated payment systems (like CloudPayments) and banking APIs, handling recursive payments and automated reporting.
  • Data Integrity: I don’t just link Slack to Airtable; I build “source of truth” systems with proper logging and status tracking.
  • Toolbox: Expert in REST APIs, Webhooks, Airtable, and Google Sheets optimization.
I prefer building clean, documented systems that your team can actually maintain long-term.
Are you open to a brief chat this week? I’d love to see your current flows and suggest how we can harden them.
Best, Mihail https://mikedevai.netlify.app/
Telegram @hely_chatbots
WhatsApp +375293761570
Hello @HRLead
I made this video specifically for you: Need help with n8n workflows (paid) - Hrlead | Loom
I’ve been building n8n workflows for 6 and 7-figure businesses for 2 years and the video shows exactly a few of them.
Here it´s my portfolio: Fran´s Portfolio - Google Präsentationen
Shoot me a message and let’s get started. franmolina.cu@gmail.com
Fran
P.S.: The video is 4 minutes. Worth it.
Happy to help — this is my wheelhouse.
I build and maintain n8n workflows connecting Airtable, Google Sheets, Slack, and custom APIs. I’ve handled structured data pipelines, webhook-to-sheet syncs, conditional logic for financial data routing, and error alerting — exactly the type of work you’re describing.
My approach: clean workflow architecture that’s easy to hand back to you if needed, with error handling so failures surface immediately rather than silently.
Can jump on a call to scope this out. What’s the best way to connect?
Les Marchand
OrionDigitaledge@gmail.com
oriondigital.surge.sh
Fintech workflows are exactly my domain — dependable, structured, built to handle edge cases that simpler automations miss.
I work with Airtable, Google Sheets, and Slack integrations regularly, and I understand the reliability requirements that financial data demands: error handling, retry logic, audit trails, and data validation before anything moves downstream.
I build n8n flows that fail gracefully (not silently), log everything, and alert when something needs human review — which matters a lot in a finance context.
Happy to look at your existing flows and propose how to scale them properly. What are the workflows you’re trying to improve?
I’ve got solid experience building production n8n workflows that match what you’re looking for. I’ve designed and deployed three systems in live environments, including a call transcription and analysis workflow that processes structured data at scale and a lead qualification chatbot that integrates multiple APIs. I’m comfortable working with Airtable, webhooks, and building reliable processes that go beyond simple point-to-point automations.
The fintech focus is interesting. While my production work has been in different verticals, I’ve worked extensively with data transformation, API integration, and webhook orchestration, which are the core skills needed for financial workflows. I understand the importance of dependable, auditable processes in that context, and I’m keen to learn the specific requirements of your environment.
Brandon
Hey there Profile - HRLead - n8n Community
Aryan here Ai automation lead since 3 years
I have worked with all these tools that you need integrating
I have worked in Finance and M&A before so I am familiar with the right tools
Let’s talk over a call?
Use this link to book-
https://axonyx.framer.ai
@HRLead Hey, saw your post about the fintech workflow project this is pretty much exactly the kind of work I do.
I’ve built n8n pipelines integrating Airtable, Sheets, and Slack for a few clients now, including one in financial data. I know how important reliability is in that environment, so I always build with proper error handling and fallback logic from the start.
Happy to jump on a quick call if you want to talk through what you’re trying to build. What’s the best way to connect?
Hey @HRLead, fintech workflow automation is one of the areas where n8n really shines compared to other platforms, mainly because of the flexibility with error handling and data validation that financial processes demand.
For the Airtable + Sheets + Slack stack, a few architecture patterns that work well:
1. Use Airtable as your source of truth for structured financial data, with n8n handling the transformation and validation logic before writing to Sheets for reporting. This separation keeps your data clean.
2. For Slack integration, set up approval workflows with interactive buttons rather than just notifications. Finance teams need audit trails, and n8n can log every approval/rejection with timestamps.
3. Webhook-based triggers are better than polling for financial data. You want real-time processing for things like payment status changes or reconciliation alerts.
4. Build in retry logic and error handling from day one. Financial workflows that fail silently are dangerous. n8n’s error workflow feature is perfect for this.
I’ve built similar systems for fintech teams and the key is getting the data model right before automating anything. Happy to discuss the specifics of your setup if you want to share more details.
Hey Muhammad! We specialize in building and troubleshooting n8n workflows for businesses — happy to help. Could you share a bit more about what you’re trying to automate or where you’re getting stuck? That’ll help us scope things out quickly.
Hi! I build n8n workflows with API integrations,
webhooks, and AI (OpenAI). Experience connecting
Google Sheets, Google Calendar, and building
structured automation flows.
Demo: Loom Message - 22 April 2026 | Loom
Available immediately. Happy to discuss your
fintech workflow needs.
